My 1989 IROC LS1/4L60E swap
#302
Re: My 1989 IROC LS1/4L60E swap
Right at $300 with tax
#308
I did get some other goodies.
My new 120A alternator. It solved my pulsing lamp issue and I swear the car runs better
Also found a guy in Washington that had these rocker emblems. I bought red ones as well. We will see which color works best with the paint.
And lastly got my Koni Yellows in. The rears are installed, Just waiting to get the fronts installed and swap front springs again.
Also snagged this BRAND NEW dash Face!
Other than that, Still saving for paint.
#309
Car: 1989 Camaro IROC-Z
Axle/Gears: 9 bolt posi w/ 3.42s
I am thinking about ls swapping my 89 IROC and was wondering how much that a/c bracket and power steering bracket was and how you found it on summit. Thanks.
#310
The AC bracket and adaptor were all I bought. The PS and everything else is all stock 98 Camaro LS1.
Just search the part numbers in the pic on summits web site and read the instructions. It will lead you to the correct adaptor bracket for whatever water pump and stuff you are using. The bracket, Adaptor, Two extra pullys and belt ran right at $300.00
#311
#312
Howdy Fellas, I havnt been here in a while and had a question.
As far as the factory tachometer in the 89 Iroc, What are the diferent methods to getting it to work with the LS? I sent mine off to a guy in Louisiana to have it fixed and when I got it back I found that it only reads 50% of the signal. Come to find out, The LS V8 signal is the same as a 4 Cylinder. So that makes sense. Question is, Are there any other solutions to getting the factory tach to work?
I have looked at the DIP Switch box that is sold by Abbotts.
http://www.atrol.com/order.htm
This little box (an ERA) costs $180.00. Are there any other alternatives? Thanks as allways.
#313
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Change the output in the tune. Stock is 4cyl, can be switched to 6cyl or 8 cyl with the click of a button
#315
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Started putting the LS together and Well, seems either the books are wrong or the torque wrench is off. Got the oil pump on and .002 gap around the shaft and wouldnt you know it!!! The books call for 18 ft lbs on this little bolt that holds the oil pump pick up tube to the pump. I may have gotten 10-11 lbs and snap!! Figures!
This same thing happened to me while I was changing out a transmission filter. Barely twisted it on there and SNAP. As I was drilling it out, I also got a metal shard in my eye and had to go get it carved out. Needless to say it wasn't fun. Sad part, is I was wearing safety glasses. I think it was stuck to my shirt or something....
#316
Metal in your eye is never good, I hope you healed ok.
No real updates on the Rock. haven't had much time to tinker. Have been taking it to a few body shops but they are nuts! 10K + to paint the car 3 stage Ruby Red. In my frustrations in trying to find a good but reasonable body shop I think I may hold off on finishing it for a few years. Some things are just not working out and we may need to find a new House. Which means The money that I had saved for paint may need to go towards a down payment on a house. Not the way I wanted this to go down but if I do that I will have a garage so That's a perk!
We'll see what the future holds and someday RubyRock will be complete.
#317
Wow! It's almost been Two years since I have seen this post. LOL!
Howdy Yall! Still working on house.
#318
Well, It's been a while again. Finally got moved into new house and getting settled in. Hoping to get going on the project again soon. While I am still looking for A painter, I am also debating Wheels and tires as well as a Power adder. I have everything to install Nitrus on it I am thinking of not going that route. Looking into a Whipple or Magna charger.
Has anyone here known of a build with either of these set ups? Would love to see clearances. Any help would be appreciated. Thanks.
#320
Pics of progress.
#321
Tearing it down
Off to see the wizard
My painter was not happy with what he found.
Bad patch job found
Weatherstrip Chanel’s rotted.
#322
Had to get new Tbar pieces
1/4 in final prime.
New weatherstrip Chanel’s from Chris at Auto Fabricators and design in the UK 🇬🇧.
#326
And now for my next trick. I will put it all back together. Ordering new carpet and must get new T-Top weatherstrips again.
#327
Looks real nice! Much better metallic, color, and shine than GM ever put on any year of thirdgen.
M
M
#328
https://www.thirdgen.org/hatchalign
https://www.thirdgen.org/forums/inte...info-rear.html
Gonna leave this here for reference.
#330
This is an awesome build and it gives me hope that I might get mine back on the road some day!
jazzdadss (01-09-2020)
