83z LS1/4L60E Swap. Zrated83
Old Feb 2, 2013 | 10:47 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I'll be doing the swap to my brothers(zrated83) 1983 Camaro Z28. Car started out with a 305 LG4/700R4. He bought a wrecked 02 SS to use as a donor car. Motor will stay stock for now, with the exception of headers. Steering and other worn out supension parts will be getting replaced.
The car already has Eibach Sportlines, UMI Subframe Connectors, an 02 WS6 rearend, and TA seats.
Motor/Trans:
-LS1/4L60E
Wiring Harness:
-Built by Jeff Tucker aka camarotucker
Exhaust:
-Hawks/Stainless Works 1 3/4" Headers
-3" Magnaflow Exhaust
Suspension:
-UMI LSx Tubular Kmember
-UMI A-arms
-Koni Yellows
-Eibach Sportlines
Rearend:
-02 WS6 w/3.42's
Brakes:
-LS1 Fronts by Scott @Bigbrakeupgrades.com
Fuel:
-4th Gen Plastic Tank
-Racetronix Fuel Pump n Hotwire Kit
The car:
Old Feb 2, 2013 | 10:51 PM
Rich92 RS's Avatar
Transmission: T56's
Re: 83z LS1/4L60E Swap. Zrated83
The donor car: 2002 Camaro SS
Took us hours, 4 neighbors, and a truck to get this thing in the drive way. All took place at midnight. Yeah our neighbors love us haha.
Motor coming out.
Old Feb 2, 2013 | 11:01 PM
Rich92 RS's Avatar
Transmission: T56's
Shell...
Old Feb 2, 2013 | 11:07 PM
Rich92 RS's Avatar
Transmission: T56's
Car arriving from Colorado.
Old Feb 2, 2013 | 11:13 PM
Rich92 RS's Avatar
Transmission: T56's
Got the engine harness removed today. Will have it shipped out and matted to the ls1 harness, once my bro decides on who to send it to. Should be getting the Fuel pump and lines next week. Will pull the motor once the fuel systems plumped. So till then this is where Im at.
Old Feb 3, 2013 | 07:16 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
very clean looking car.and wow that donor car had seen better days
Old Feb 3, 2013 | 08:07 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
The Black Z is Beautiful!
Old Feb 3, 2013 | 08:03 PM
Rich92 RS's Avatar
Transmission: T56's
Now it'll have the drivetrain to match.
Old Feb 3, 2013 | 10:03 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Nice looking car and swap. Also looks like lots of third gens around your house.
Old Feb 3, 2013 | 11:28 PM
Nick88T5iroc's Avatar
Car: 1992 RS
Engine: Tbi 305
Axle/Gears: 3.08
Great looking car! Do you know what hood that is? I like it.
Old Feb 3, 2013 | 11:38 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
That is one clean Z
Old Feb 4, 2013 | 07:56 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Man, it's like F-body central around your house! His car is going to be awesome once the swap is finished. It's already a beautiful car. It's very clean looking!
Old Feb 4, 2013 | 10:07 AM
toxzzic1's Avatar
Gorgeous car! I would really like to know where he got the hood.
Old Feb 4, 2013 | 12:52 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Awesome looking Z!
Old Feb 4, 2013 | 03:39 PM
Rich92 RS's Avatar
Transmission: T56's
lol yeah we've got 4 thirdgens, and a fourthgen. Driveway space is limited. The hood was custom made by a fellow member. He made two, and this was his prototype I think.
Fuel pump and filter came in today, still waiting on the lines and fittings.
Old Feb 17, 2013 | 09:20 PM
Rich92 RS's Avatar
Transmission: T56's
Finally got all the fuel system parts, and a day without rain. Dropped the stock tank, and got the 4th gen plastic tank installed. Gutted the fuel pressure regulator in the 4th gen tank, since we're running a vette fuel filter.
Gutted fuel pressure regulator
Old Mar 17, 2013 | 07:19 PM
Rich92 RS's Avatar
Transmission: T56's
Got the motor and trans pulled today.
Old Apr 4, 2013 | 07:17 PM
LivinLarge's Avatar
Any updates??
Old Apr 6, 2013 | 07:59 PM
Rich92 RS's Avatar
Transmission: T56's
No real updates. Sold the old 305, hopefully the 700r4 sells soon. Been stripping down the engine bay, getting it ready for some paint. Need to replace the battery tray, and remove the rust first.
Old Apr 8, 2013 | 08:42 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
cool project...for some reason zr1's just look at home on a third gen.
Old Apr 8, 2013 | 10:53 AM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I noticed that you pulled the motor from underneath. Is that easier? What's involved? I'm getting ready to pull my 305 and tranny out of my 83.
Old Apr 9, 2013 | 11:48 AM
Rich92 RS's Avatar
Transmission: T56's
They sure do. Got two cars rocking them, and two extra rims sitting in the shed
Some will say its easier from the top and vice versa. Its really just preference.
Theres allot more steps but for me its just easier from underneath. Out of the 4 fbody motors Ive pulled, 3 of them have been from under. I can honestly say I'll never pull one from the top again, at least not without that leveler thing. If you have the ability to raise the car up high enough and the space its a breeze.
Take a look at these links. Its for a 4th gen but it gives you a pretty good idea of what to do/expect.
http://ls1tech.com/forums/general-ma...ls1-fbody.html
http://ls1tech.com/forums/generation...ne-bottom.html
Some differences:
You'll need a spring compressor to remove the front springs, or whatever safe method you use.
Need to remove the triangle braces, or at least unbolt them from the frame.
Unbolt idler arm, or both outer tie rods at the spindles. I removed the spindles altogether alittle while later cause they were leaning, and heavy.
You wont need to unbolt the steering shaft.
Just go slow and think about whats all connected to the motor, transmission, and front kmember.
Old Apr 9, 2013 | 08:27 PM
Strick1's Avatar
Thanks, Rich, I went through the links. Interesting.
Old Apr 9, 2013 | 08:30 PM
Strick1's Avatar
Hey Rich92, I also noticed you swapped fuel tanks to a 4th gen. They bolt right in?
Old Apr 10, 2013 | 02:21 PM
BADNBLK's Avatar
COTM Editor
Nice man! Your brother was talking about doing it, and on our local boards said he started it, but I had no clue he had THE BEST BROTHER EVER doing all the hard work while he plays around out here with us in the snow! His car is gonna be so killer when you get done. Jealous for sure
Old Apr 11, 2013 | 04:16 PM
Rich92 RS's Avatar
Transmission: T56's
Yea the tank sits perfectly in the stock location. The rubber filler neck needs to be trimmed, and you'll have to choose how you want to connect the fuel lines.
Haha thanks. Car should be ready in time for some summer cruises up there.
Old Apr 12, 2013 | 09:36 AM
Strick1's Avatar
Thanks. There is a lot of stuff on the top of that fuel tank. Did you use the stock 3rd gen steel fuel lines from the tank to the front?
BTW, I have a thread started on my swap: https://www.thirdgen.org/forums/ltx-...5-caprice.html
Old Apr 12, 2013 | 07:59 PM
Rich92 RS's Avatar
Transmission: T56's
For my Iroc I used the stock fuel hardline. For this one we decided to do nylon braid all the way to the front.
Ur swaps looking good. We got some rust in the front passenger floor board aswell. Hopefully it stops there, wont know till after I pull the interior out.
Old Apr 12, 2013 | 08:07 PM
Strick1's Avatar
Maybe we spilled all the drinks over in the pass side. Or we waited for the passenger to try and take a drink and we hit the brakes.
Old Apr 17, 2013 | 03:37 PM
Rich92 RS's Avatar
Transmission: T56's
Engine bay painted.
Old Apr 17, 2013 | 05:35 PM
Strick1's Avatar
What type of paint did you use on the engine compartment?
Old Apr 17, 2013 | 05:41 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Paint looks good!
Definitely couldn't have asked for a better bro
hahaha
Old Apr 18, 2013 | 08:42 AM
Rich92 RS's Avatar
Transmission: T56's
Rustoleum rattle cans.
Old Apr 26, 2013 | 07:37 PM
Rich92 RS's Avatar
Transmission: T56's
Hoist is back so the motor will be getting painted tomorrow. If its not raining Sunday, I'll be stuffing the motor in. Got the LS1 front brake kit from Scott @bigbrakeupgrades.com a few days ago and they look awesome as usual. Took out the kmember and front suspension pieces for some pics. Got all new brake lines aswell. Harness should be here next week hopefully.
Old Apr 26, 2013 | 07:55 PM
Strick1's Avatar
My son and I just finished watching a video by Spohn about their K-member. Looks impressive as do your pictures. We got our K-member out today and it really is easy to remove. I'm working with a LT1 and I still don't see where I have to notch out my K-member because the motor mounts are right on the leading edge of the K-member.
I like your engine bay. We haven't decided on a color for the Camaro and would like to do the engine bay the same color as the exterior, BUT we do like the black.
Old Apr 28, 2013 | 08:13 PM
Rich92 RS's Avatar
Transmission: T56's
I painted my Irocs engine bay black aswell. I Didnt want to do a body color engine bay because when I eventually get it repainted the black will still go well with the exterior. Cant go wrong either way. Obviously my bro didnt have this dilemma, having a black exterior.
Cleaning/prepping the motor for paint took longer than expected. Still have the accessory's to paint, and valve covers too. O well, no point in rushing. Heres the motor:
Old Apr 29, 2013 | 07:52 AM
Strick1's Avatar
Nice job on the motor. Silver, now that's different. Never thought about silver, looks cool.
Old Apr 29, 2013 | 09:08 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
I've been thinking about silver for the 6.0 as well. I liked the look of the aluminum block in my car, so I thought I'd replicate the look again.
Old Apr 29, 2013 | 08:21 PM
Strick1's Avatar
The only thing bad about it might be that it may show dirt or grime easier.
Old May 3, 2013 | 06:04 PM
Rich92 RS's Avatar
Transmission: T56's
Got the wiring harness back. Huge thanks to Jeff Tucker aka camarotucker for building it. It looks awesome. Shooting for next weekend for a first start.
Old May 3, 2013 | 08:25 PM
Strick1's Avatar
I'll be watching to see how well the harness fits and if it works. This is the next biggest thing I have to figure out for my engine swap. I take it Jeff has done a few of these?
Old May 10, 2013 | 03:44 PM
  #42
Rich92 RS's Avatar
Transmission: T56's
Got the motor in on Wed. UMI Kmember fit great. A little tug here and there and everything lined up good. Only took 50 mins to get it all bolted up. Not to shabby lol
We forgot to reinstall the trans dipstick before lowering the car onto the motor/trans, and it sucked with the motor/trans already in.
Old Jul 1, 2013 | 11:21 PM
  #43
Rich92 RS's Avatar
Transmission: T56's
Wow its been forever. Been dragging my feet for awhile, but now I really need to finish it. Motor in my Iroc may have ate a bearing. Its been sitting for a few days, so I'll get to it soon enough and have a look.
Got the Stainless Works/Hawks headers installed without to much trouble. Drivers side dropped right in no problem. Passenger side also went in from the top: after removing the dipstick, valve cover, and lifting the motor up abit. Surprisingly enough they didn't need to be tweaked away from the frame rail. I know plenty of people have had problems with fitment, but we got lucky.
Old Jul 1, 2013 | 11:23 PM
  #44
Rich92 RS's Avatar
Transmission: T56's
Re-wrapped the engine harness Tucker built for us in Techflex F6 sleeving, then started plugging everything in. Ran the harness threw the passenger fender like stock, and into the interior. Got the fuel pump wired up using the 4th gen fuel pump bulkhead. Got some of the wiring for the 4th gen cluster, and headlight/dimmer switch started.
Built some trans cooler lines out of AN line and fittings. Diagram I used is below. Credit goes to Pocket for drawing up the diagram I believe.
"The PNs in the diagram aren't correct for the trans side
Trans takes 1/4 NPT, radiator 1/2 x 20
45* hose ends on the trans, rad upper is a 90* and 45* lower"
F6 Sleeving
Cooler Lines
Attached Thumbnails 83z LS1/4L60E Swap. Zrated83-trans-20lines.png
Old Jul 20, 2013 | 07:13 PM
  #45
Rich92 RS's Avatar
Transmission: T56's
Cluster, and headlight switch all wired up.
As most people know when installing the passenger side ignition coil bracket, the rear coil tends to hit the hvac box. Instead of grinding the box for clearance i decide to try and modify the coil bracket. I ended up cutting of the last portion of the bracket, and bending the ends down. Pics below.
Old Jul 22, 2013 | 11:16 AM
  #46
dprest68's Avatar
Engine: cammed LS1
That's an interesting idea. I might have to give that a try.
Old Jul 25, 2013 | 08:21 PM
  #47
Rich92 RS's Avatar
Transmission: T56's
Got the a-arms, springs, spindles, struts, and camber/caster plates installed.
Old Jul 26, 2013 | 07:27 AM
  #48
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Nice progress!
Old Aug 17, 2013 | 06:49 PM
  #49
Rich92 RS's Avatar
Transmission: T56's
Cars finally sitting on all four, for the first time in a loooong time. Hopefully that front end settles down abit. Got the motor started last month, but dont have the vid on hand. VATS kept it from running long.
Ran into a problem with the stock torque arm for the 83. Ordered a stock style poly torque arm bushing for a 02 camaro, and the 83z's torque arm is stamped the opposite way from later years. The front of the torque arm is stamped kinda like this { on the 83, and they change to this }. Luckily I had the stock torque arm off my Iroc and which is stamped the same way as the 4th gens.
Also ran into a problem with one of the new rear koni yellow's. One's leaking a bluish fluid so hopefully we can get a replacement shipped soon.
Front suspension installed;
On all four;
Old Aug 17, 2013 | 07:23 PM
  #50
Rich92 RS's Avatar
Transmission: T56's
Building the air intake. Consist of an 4" AEM Filter, and Airaids 4" UBI kit. The U build it kit doesnt come with any couplers so I bought them from siliconeintakes.com
The MAF will be clocked so the connectors are hidden.
