finding tdc on lq4
Old Feb 11, 2013 | 07:56 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
finding tdc on lq4
Im going to change valve springs on my lq4 with the heads on the motor and want to try putting the piston up to tdc to keep the valves up while i change springs. Im doing this alone so i dont have anyone to feel for air escaping. Does anyone have any ideas how to do this? Thanks for any help
Old Feb 11, 2013 | 11:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remote starter switch.
Old Feb 11, 2013 | 11:22 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Re: finding tdc on lq4
This worked for me on an l05....
Old Feb 11, 2013 | 11:23 PM
MMroc86's Avatar
double post... opps
Old Feb 12, 2013 | 08:15 PM
ransam's Avatar
The engine is bolted to the k member and hanging from the hoist with no starter so the remote starter wont work and i dont hve the adapter to screw into the spark plug hole otherwise i would just hook the compressor to it to hold the valves up any other ideas?
Old Feb 12, 2013 | 08:33 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Rope truck will work perfect for this situation. Thread as much small rope into the cylinder as you can, and rotate the engine with a breaker bar intil it stops. The piston will squeeze the rope into the top of the cylinder and combustion chamber, holding the valves up firmly and making it impossible for them to fall out of the head
Old Feb 12, 2013 | 11:21 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Rope trick can work...
If the motor is out, just remove all the plugs, rockers and pushrods. Keep the rockers and push rods in order... It'll turn over with a socket on the crank bolt no problem. Then use an old push rod or a screw driver in the spark plug hole and slowly raise the piston until whatever you stick in there stops going up. Heck with it out of the car you can probably shine a flashlight down in there and see the piston when its at the top.
Piece of cake. And dont forget, two pistons are always at TDC at the same time. So you can do two cylinders without rotating the motor. After you have one at TDC, the rest are easy.
J.
Old Feb 13, 2013 | 06:40 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
I like the screwdriver method, and that's what I do at home. Not sure how well it will work without the air fitting to pressurize the cylinder to hold the valves up though.
Old Feb 13, 2013 | 12:55 PM
five7kid's Avatar
The adapter for the air hose to the spark plug hole is about $10 from Sears, NAPA, probably most chain parts stores.
I've never tried the "rope trick", seemed too tricky. Using the piston itself allows valve movement that may not allow you to compress the spring enough to get the keepers out. The air hold just depends upon the air pressure supply not being interrupted.
Old Feb 14, 2013 | 05:25 PM
ransam's Avatar
Ok if i buy the fitting to hook the compressor to the head what should i adjust regulator to? I would guess i woldnt want 150 psi going into the motor would I?
Old Feb 14, 2013 | 06:16 PM
five7kid's Avatar
No reason not to.
Mine starts up at 85 psi, off at 115.
db057
Apr 28, 2019 07:45 AM
Breazlan
Sep 25, 2015 11:20 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
rjcme
Sep 5, 2015 01:23 PM
