6.0 carb swap problems (HELP!!!)
Old Feb 14, 2013 | 12:07 AM
arustedspork's Avatar
Car: 85 T/A
Engine: 6.0
Transmission: th350
Axle/Gears: 3.23 (something better soon)
Alright I need help because we are about to roll the car down a hill.
Got the LS1 elderbrock carb swap kit however we have no spark.
We have tried two MSD boxes, replaced cam and crank sensor.
Coils have power however no signal to spark.
We have tried everything to try and solve this problem and we are out of ideas.
So, any thoughts?
Old Feb 14, 2013 | 12:18 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 6.0 carb swap problems (HELP!!!)
First thing to do...Dont Panic! Lol I know..easier said than done but it helps when solving things like this.I dont know anything about doing a carb swap but I do have a quick question. Coil has power..even during crank or just with key on..same for the msd box?
I made a stupid mistake of wiring the wrong ignition wire for my ecu to the ign wire that wasnt hot during crank.Motor just turned over pretty quick with no compression it sounded like lol..doh,had me scratching my head for a day as i was burnt out.
The msd box only needs how many sensor inputs to provide spark? gotta think it through and it will be something simple i bet.
Old Feb 14, 2013 | 04:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
does it show rpm on the computer program when cranking?
Old Feb 14, 2013 | 04:03 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Do you have a puck in it?
if its the LS1 edelbrock it needs one of the 6 pucks in it for it to spark
Old Feb 14, 2013 | 04:33 PM
Car: 85 T/A
Engine: 6.0
Transmission: th350
yes, yes and yes
Old Feb 14, 2013 | 04:38 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
is the block grounded out good and is the MSD box grounded good ( i stress GOOD)
Old Feb 14, 2013 | 06:18 PM
Car: 85 T/A
Engine: 6.0
Transmission: th350
I should be we have grounded the battery to the frame, the engine to the frame and the box and the battery are grounded on the same terminal.
The only thing I can think is the starter is not getting the engine to a high enough rpm. Going out now and will test this theory.
Old Feb 14, 2013 | 09:27 PM
lunati397's Avatar
you should always have spark regardless of rpm hows the voltage on the battery what year block is it and what kind of top end do you have is it possible you have a LS3 with the 58x reluctor ecu trying to read the 24X wheel
Old Feb 14, 2013 | 09:28 PM
lunati397's Avatar
I dont know if its a switch setting or not on the MSD to change between the Reluctor wheel setting
Old Feb 14, 2013 | 10:26 PM
Car: 85 T/A
Engine: 6.0
Transmission: th350
Update.
As of right now summit is sending me the better 6010 msd box (yes and i am getting the harness) so hope fully the better box will help my cause
Old Feb 16, 2013 | 10:39 PM
Car: 85 T/A
Engine: 6.0
Transmission: th350
Figured out the problem... and it was dumb. When we put the bud into the crank sensor one of the pins got bent.
Causing it to not get power.
In good news it's running now and you can go to the other thread I have and fallow the link and see it run!!!
Old Feb 17, 2013 | 09:33 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
told ya it would be something small stupid that causes a big headache. Glad its running and hey..atleast summit sent ya a new box and harness lol
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
