Sizing pushrods in built LS
Old Feb 16, 2013 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the stroked LQ4 I'm building, reminder this is the cam:
And 823 L92 heads. The LS book I have says to put the valve at half lift and check if the rocker is on the middle of the stem, but that seems a bit weird. I checked for zero lash with an adjustable pushrod, and came up with 7.355".
I remember seeing someone post to go for .050" to .100" preload. If that's correct, then I should get pushrods that are 7.405" to 7.455" long. Stock are 7.400", I believe.
Tried searching, didn't find anything meaningful.
Old Feb 18, 2013 | 12:00 AM
five7kid's Avatar
Well, my son's 5.7 came with TSP .080 wall 7.425" push rods and an unknown lumpity cam. He's put an LS6 cam in it after a refresh, and those push rods seem too long. So, he's going to put a set of LS6 push rods I had laying around, and I'm going to use his TSP push rods. Win/win, I think.
Old Feb 19, 2013 | 03:04 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Sizing pushrods in built LS
50-80 is where you want to be. 100 is too much for safety sake imo. IIRC 1 turn of the rocker arm bolt is 45 thou
Adjustable pr length checker is what you need
Old Feb 19, 2013 | 07:46 PM
five7kid's Avatar
I used an adjustable push rod to establish zero plunger preload.
The 7.425" pushrods will put me at .070" plunger preload. Close enough, eh?
Old Feb 21, 2013 | 09:58 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Looks like win / win to me.
Old Feb 25, 2013 | 05:47 PM
five7kid's Avatar
Probably is. He isn't squawking about giving up his fancy aftermarket pushrods for factory pieces: but then he knows I'm using them in my LS6-clone in the Camaro and they're doing fine, plus he probably realizes I haven't said anything yet about reimbursement for his rings that I included with an order for my own stuff from Summit...
Old Feb 25, 2013 | 05:54 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ya 70 is a go imo
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
ericjon262
Sep 11, 2015 06:07 PM
timonator
Sep 10, 2015 07:55 PM
BOOT77
Sep 5, 2015 03:55 PM
