pilot bushing or bearing
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
Just wondering if there is a preference between the two. I am about to put my ls swap together, and the t56 i bought separately. The engine was from an auto f-car, so not sure what they use from factory or if it even matters.
thanks in advance guys !
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: pilot bushing or bearing
bushing you dont have to worry about failing
bearing you have to worry about failing try lurking around ls1tech and searching they can fail
get the bushing and you have no worrys there is no performance gain using either or
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Factory used a bearing. Bearings can fail, bushings are considered to be more durable. That being said, I have wiped out 1 bushing in short time with a fresh rebuilt trans, so bushing failure can also happen, just seems to occur less often than with a bearing.
Engine: 305 to 350
Axle/Gears: 10 Bolt
from what ive seen bushings can fail but its more than likly have to do with trans or sumthing i really dont remember exactly but
bushiing are made of Bronze IIRC soft metal.. so if you dont install trans correctly you can mess up bushing fairly quickly
and sense bushing is a softer metal you wont damage your input shaft rather have bushing fail then input shaft get jack
ive seen bearing mess up input shaft when not replaced scoring input shaft tip
Car: 92 Ttop Z28
Engine: Cammed 6.0
it is possible just not common... lol howw you manage to do that ? and with fresh trans ?
Engine: 5.0 TPI
Transmission: auto
thanks guys, i was thinking the same thing about the bushing not being as prone to failure.
I prefer a bushing since its a wear item. Sure the service life is less than a bearing, but as cheap as they are who reuses them?
If a bushing fails, the bushing is destroyed. $5-10 part
If a bearing fails, the bearing and input shaft are destroyed. $20-40 bearing $200+ input shaft
Easy choice for me
Just to make searches easier:
Classic SBC pilot bushing
OD .594"
ID 1.094"
Length .746"
Dorman 14650 is cast iron
DO NOT USE THIS ONE
More info on bronze bushings in here
http://www.hotrodders.com/forum/gm-p...-s-180286.html
Easy choice for me
OD .594"
ID 1.094"
Length .746"
DO NOT USE THIS ONE
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: 5.0 TPI
Transmission: auto
i know the older cars always had bushings, that's what made me ask about why the switch to bearings now. I guess sometimes new ideas are not always better ideas. Thanks Pocket for that link to hotrodders thread, very interesting.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
BUSHING! I forgot to take the P/N last time. I just asked for a 69 Camaro with a 350 and its the right one. They've been the same size for a long time.
Im another person that blew out a bushing due to a trans issue...and I was really glad it wasnt a bearing because Ide be replacing my input shaft for sure.
What happened was, one of the alignment dowels between the trans and the bellhousing got pushed into the bellhousing during assembly. This allowed my trans to clock itself out of place. yeah.. Ugly... So it wallowed out the bushing, and I was getting a nasty vibe when I would rev with the clutch in. Red flag red flag! Tore it apart and caught it before too much went wrong. So...Ill be using the bushings from now on.
Input shaft end was still perfect. And you can see how much material was taken out. Yikes!! But had that been a bearing, not only would my input shaft probably be trash, but the car might have been undrivable (not that i should have driven it more like it was) and getting the old bearing out would have been a pita probably.
J.
J.
Engine: 5.0 TPI
Transmission: auto
yea i'd say that was a lucky break having the bushing instead of bearing. So the SBC and LS engines use the same bushings ?
Engine: 305 to 350
Axle/Gears: 10 Bolt
I believe so I think there the same if I remember correctly
Early style ls1 had bushing and later style had bearing from factory
Another option Kevlar bushing
A bit more but there's options
http://www.ws6project.com/user_stor/...c5f1384a9c0870
