Ls1 swap tutorial video?
Car: 88 Camaro IROC, 92 Camaro RS.
Engine: 305 tbi, LT1
Transmission: 700r4, 4l60e
Axle/Gears: 3.43
I think it would be a awesome idea if someone would make a Ls1 swap step-by-step video. It would be such a great help to not to only me but everybody doing the swap. Someone should make one!
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: Ls1 swap tutorial video?
I'll do it, i am soon gonna swap mine in this summer. I'll be sure to do it in HD.
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Car: 84 firebird
Engine: 355
Car: 84 firebird
Engine: 355
its a great idea! i have been thinking about doing a swap for awhile now but after doing all the reading i get discouraged on actually completing it and dont do the swap a video could show how its not that difficult like many people say
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
That would help countless of our fellow third gen members and answers tons of questions, thats an awesome idea!
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i've done several of these swaps now...the first one was pretty intimidating, but it's not near as bad as you might think.
Car: 84 firebird
Engine: 355
Oh i agree. they are probably not as bad as i believe, however my skill level for that swap is not at that point yet. i think its more all the wiring that turns me away from it, not a fan of wiring haha
Engine: 7.0L
in a nutshell, all pink get switched 12v, orange get all the time 12v, and black get ground. it will run if that's all you do, lol
Car: 84 firebird
Engine: 355
lol well i do know the basics, carbd motors are simple a whole 4 wires to run it soon i will do an LS swap BUT back to the subject at hand a video will be very helpful haha
Engine: 7.0L
oh, you're doing a carb setup? man, you don't need a video, lol.
Car: 84 firebird
Engine: 355
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Dropping an lsx in a thirdgen isn't hard to do.
Only thing i'm really figuring out is my fuel lines and tank but I think i have my answers.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Engine: 7.0L
Transmission: 4L80E/4L80E
I kept silent when you first posted this, because I knew I wouldn't be the one doing it.
My thoughts are I'd need a dedicated videographer because setting a camera on a tripod and turning the camera on would probably result in hours of useless data that would have to be extensively edited, and what you're really doing probably wouldn't be captured unless someone could point the camera where it needed to be as the process was being accomplished (hard to do with greasy hands, and while your hands are otherwise occupied). And, as I'm finding out in my 3rd LS swap (first two being 3rd gens, the 3rd not - 4th if you count the work we've done on my son's S10 Blazer), I tend to figure out things as I go, so the task would be done before I figure out it should have been videoed.
There are also so many variables from swap to swap, I'm not sure how you could cover them all. Are you doing a stock swap, or modifying? Manual or auto trans? Starting with a manual or auto car? Starting with a non-EFI or EFI car? Factory 4th gen f-body exhaust, or headers? AC or non-AC? Aftermarket tubular K-member or stock K-member? Whose swap mounts? Where will the PCM be mounted? And as has been hinted at, factory EFI, aftermarket EFI, or carb? (many variables with each of these) Daily driver, weekend cruiser, or trailered to the track? Emissions-compliant, or not? What I've done for my swaps would be almost completely useless for Matt (although he did sell me a set of Cometic head gaskets, which he probably wishes he had back...). Okay, we could go on, but you get the picture.
I'm not disapproving of someone taking a shot at this, and I'd be happy to post links in the LS swap sticky. I just want to set reasonable expectations.
Engine: 7.0L
Nah, those head gaskets wouldn't work for the big bore, and not worth using on my junkyard motor. And I don't know if you remember, but I was efi for a little while.
What might be better is a PowerPoint presentation, or several presentations, outlining the variances and covering in detail what's going on. But then, why not just read the sticky? Lots of successful swaps done on this site from reading them. My theory is, this shouldn't be your first engine swap, and if you can't get it done with the info already readily available on this site, then maybe you should hire some help.
Engine: 7.0L
actually, i have built more efi cars than i have carb'd. my little bro's iroc is efi 5.3 and my wife's 71 chevelle is efi 5.3.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Engine: 7.0L
"streetable" is too subjective to use in an argument in my opinion. my carb'd setup sees a ton of street miles.
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
"Street able" is subjective to the driver. I grew up with carbed car and have zero issues driving them. Some friends on the other hand, can't even get my 73 Chevy plow truck out of the yard, and consider that not even "street able".
As far as info here for ls swaps, its absolutely amazing. I was doing reading on s10 websites for a possible project, and they don't even have pinouts available for the s10s, let alone entire spoon-fed guides to wiring like we are lucky to have here. This place is truly a wealth of knowledge, most other car communities would be jealous to see the mass of info we have.
Axle/Gears: 3.43
I see this was a good thread to start
hopefully one of you guys are awesome enough to make this video.. I would if I knew what to do. I really don't want to go carb like alot of people, I'm trying to get good mileage along with good power.
hopefully one of you guys are awesome enough to make this video.. I would if I knew what to do. I really don't want to go carb like alot of people, I'm trying to get good mileage along with good power. Last edited by Dvolion11; Apr 4, 2013 at 08:47 PM.
Car: 84 firebird
Engine: 355
It looks like this whole thing is spiralling out of control..Everyone is making valid points to every variable of what kind of swap, do's and dont's,etc...If he wants to make the video he must be prepared for the extra work its going to take (like five7kid said editing,camera angles,etc.). Alot of members would benefit from seeing physical objects instead of reading about them. I myself have read and read and read some more,but there are still things im not so sure and not comfortable doing an LS swap my self. I have done plenty of carb swaps no problem and can do v6-v8 swap in my sleep now..thanks to this site (the reading and stickies) i knew NOTHING and it did take time and figure out on my own.Everyones skills move at a difference pace. Some people need a video, others need notes,and some do it from pure knowledge. Hopefully this comment isn't going to be made negative..thats not my intentions lol but to make it short and simple some people need that extra help lol
Car: 84 firebird
Engine: 355
Axle/Gears: 3.43
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
theres probably enough youtube videos of the parts of the swaps to make a complete compilation of the entire swap into a car in general, in stock form. pretty sure no one would want to piece them all together though.
Street Lethal
Apr 30, 2019 12:14 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
