Front Mount Ls1 w/ Truck Mani Kit
Old Apr 28, 2013 | 12:40 AM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
I've been gathering parts for quite a while now, and finally got another car so the camaro can go back under the knife.
Anyways the plan at the beginning was,
-great drivability
-awesome power without too much lag
-close to stock appearance
-as always, a semi-budget build (at least it started that way)
A couple months ago I knew I wanted more power but wasn't sure on the route to take. I knew after cam and heads I'd end up wanting more so I figured boost would be the best route. Did some research for a while and ended up with
-ls1 with forged pistons and rods w/317s and ls6 intake
-t56 and 9in
-tc7875
-4th gen truck manifold kit
Parts so far:
That's going to be the basic idea. At the time I wasn't sure how well the truck manifolds would fit, but of course I had already put my deposit down since it was a GP. I did end up getting a GREAT deal on it regardless.
I know I'll end up redoing the hot side as the driver side manifold will go right through the steering box and the passenger side will need to be v banded. I researched a bit and read that the fbody manifold will work in place of the truck on the driver side.
Anyways... Enough talking. I just started this weekend and will try to take as many pics as I can
Old Apr 29, 2013 | 06:53 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: 305>350>ls1>front mount build
that tc78 is very pleasant to drive with, dam near instant boost. if all ur stuff is set up correct. i dont know of any other quality turbo for the money.
Old Apr 29, 2013 | 07:05 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Lsx front mount w/ truck manifold kit
Awesome! I'm really excited and can't wait to get the hot side started. Soon enough!
Do you speak from experience? I imagine spool shouldn't suffer to much since I have their new 75mm turbine wheel. I hope to see 9s in the 140s. That's my real goal. I imagine that's about 750whp~
Old Apr 29, 2013 | 08:43 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Saving for a turbo build aswell, cant wait to see more progress pics. What brand kmember is that? Looks pretty bare.
Old Apr 29, 2013 | 08:51 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Pa racing. It probably looks so bare since I'm going with coilovers, so it doesn't have the top mount for those.
Old Apr 30, 2013 | 10:32 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Been a little bit. Found time to remove the a/c, egr and the alternator. What a difference with all the open space. Took some time today since the a/c is gone to take the manifold off and try on the truck mani. What a pita to remove the dipstick, you can see I banged up the paint pretty good in some areas trying to wiggle it in. Finally got the dipstick out and noticed that its not the frame the flange hits, it's the kmember.
Luckily I already have my pa racing kmember and hope to put it in this weekend to see where the engine sits.
Old May 2, 2013 | 10:39 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: Front Mount Ls1 w/ Truck Mani Kit
Got what I wanted accomplished tonight! Kmember is bolted in.. By one bolt for now
What a difference though, MUCH more room was left than I thought.
I am having trouble with one motor mount bolt, but I imagine it just needs to be aligned a little.
Also got my fuel pressure gauge and shaved down one hole to fit the eboost
Kinda hard to see but oh well.
Old May 3, 2013 | 05:40 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Sweet!
Old May 5, 2013 | 08:53 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Little update...
Fans are mounted on the radiator. I test fitted it and the top fan will need to move down one or two rows, however I could squeeze it in and it fit perfect. Ill get pics soon.
Also realized BOTH manifolds will need to be cut. The passenger side I actually got bolted on but I had to take a stud out to get it on. I figure ill be able to cut a triangle out if that makes any sense and use a hammer to bang it into place. I imagine it should fit fine but then ill have redo the crossover.
Driver side wouldnt even bolt up. It hits the steering link plastic cover.
Old May 8, 2013 | 10:10 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Update:
I took out the steering linkage, and gear box. The manifold then fit very well.
Hopefully getting them in was the hard part, next will be v banding them.
The pass. side is the real problem. It's extremely close to the kmember and I had to take a stud out so it would even fit.
Last but not least, I put the crossover on.
You can tell from the picture that its too close to the rad., so I'm going to see if I can cut some of the tube off the crossover to make it sit back and higher to accommodate the sway bar as well. I figure ill need spacers anyways though. That's about where I'm at now. I'm going to be buying some vbands soon and will get pictures up soon.
Old May 19, 2013 | 12:59 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Update:
Got the vbands and also tacked, fitted, and grinded/cut the hot side to face up and backwards a bit to accommodate the turbo.
Everything seemed to fit fine so it'll go out for welding Tuesday!
The little bit of clearance to the radiator. It i see any problems, ill stand the radiator up but I think it'll be okay.
Old May 19, 2013 | 08:39 PM
Kyle86's Avatar
Car: 86 Camaro IROC-Z28
Engine: 4.8 LS 68mm turbo
Transmission: Turbo 350
Axle/Gears: 3.08 10 bolt
Wow good job getting that kit to fit you have a lot of patience, I would have that thing mangled up by now ha ha. I like that turbo too! I planned on doing something very similar as well with modifying the truck manifolds then I decided to flip them and move turbo to driver side. Glad you got it to work out! One reason I love these diy builds is seein how everyone else goes about making their stuff work. More than one way to skin a cat haha. Anyways looking forward to seeing the rest of the build thanks for sharing pics I know you will hit the 9s dude! I got a turbo lsx build thread goin too with 10s on my mind check it out sometime. Good luck looking forward to seeing the rest.
Old May 19, 2013 | 09:23 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Thanks man! And I owe my patience to my dad. He's the one that keeps me level headed through most of this. Kinda my knowledge and his know how. I really can't wait to see it welded up, then it'll be the piping from the intercooler to the turbo. I have a idea but I'm not sure if it'll be problematic or not.
I want to do a quick "U" right off the intercooler which will wrap around right behind it and run between the rear of the intercooler and a plastic shroud. Then have a 90 degree welded on and cut a section of the shroud out to accommodate the pipe which will then have a short 45 degree welded to that which will then have a straight coupler to the compressor outlet.
I'm not sure if the sudden 180 degree turn though will cause a restriction or not for the air to flow smooth/properly. You can see in the pic below
If I can get it done how I want, it'll be perfect IMO as ill have no worries for ground clearance with any of the piping.
Old Jun 3, 2013 | 10:56 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Little update guys.
Kinda been farting around waiting from some money to drop into the fuel system. itlll give me a reason to drop the rear so i can install some goodies i got for a great deal at work.... FREE. lol : )
Whats been done since the last update.
Messed with the new fan relays and mounted them. Currently working on wiring them
Started wiring my gauges up
And almost finished. Still need to run a couple more.
Also I decided to venture away from coilovers. Itll be cheaper and i think a better choice to go with the free package of eibach springs and tokico shocks/struts I got. So which mean im going to need to send my kmember back and also my aarms to be modified for spring perches. The k-member will also have tabs welded on for a custom power rack and pinion from unisteer. No idea on any of those specs yet. Ill have to give them a call soon and talk to them a bit.
Old Jun 4, 2013 | 12:29 PM
Kyle86's Avatar
Can't argue with free.
Old Jun 4, 2013 | 04:32 PM
Pocket's Avatar
Car: 91 Trans Am
You can convert a coil over to coil spring K-member pretty easily
For my spohn unit, I welded a half circle plate on the plate in the area pointing to the engine then welded a short length of 4" exhaust tubing in the center to locate the spring
If you PA unit's connecting plate doesnt ride along the frame rail then cut it out and weld in a new one with a circle plate and a center locator
Also, the main hoop isnt notched and looks strikingly similar to the Spohn design. How is your tie rod clearance throughout the susps travel?
Old Jun 4, 2013 | 08:58 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
I'd love to see a picture of how you did it if you don't mind. And unfortuantly, I don't have a welder on hand. The one used to tack the pipes was on loan. I'm going to see if I can try to get it again, but if not I don't mind sending it back. Unless the price is stupid expensive of course. And I haven't had the steering back on yet, so I can't give you a answer on the tie rod clearance yet.
Old Jun 5, 2013 | 06:44 PM
Pocket's Avatar
Car: 91 Trans Am
I dont have any pics of the mod because it was a last minute mod
If you dont have a welder handy, then dont worry about it. Cut off the bar and order a set of K-member coil spring adapters from UMI ($100ish)
http://umiperformance.com/catalog/in...roducts_id=690
Old Jun 5, 2013 | 09:47 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
great work so far I have a ky turbo kit that I got really cheap and will be doing the same thing soon just have to finish some other projects first ill be going all holley (intake ecu harness injectors pump ect)
the dominator pump is great too its quiet and you can run one or both pumps
Old Jun 5, 2013 | 11:38 PM
Z28FAST1's Avatar
Subscribing!!! I was close to getting in on the group buy but thought I would wait to see if there were any major clearance issues.
Can't wait to see it done!!!
Old Aug 23, 2013 | 07:30 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Figure its time for a little update:
Got the alt. relocated
Also got my BOV pipe back. The flange as you can see in my earlier post pointed straight up at the bumper support, now fixed.
Without turbo
with it
You cant really tell, but the rad. support got notched so i had a little more wiggle room.
Starting to get buttoned up a little
Underside with the swap bar back on. (had to make some 2 inch spacers)
Old Aug 23, 2013 | 07:47 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Oil lines drilled, tapped and installed
No more ugly cruise control unit which didnt work reguardless
The only piping which needs to be finished. I figure ill extend the 180 a couple inch and get a 90 degree welded to the end of the the pipe which will meet the turbo instead of 90's.
And last but not least, more stuff!
Thats basically where im at now. I did get to start it just to satisfy myself, which i did lol, and couldnt be happier!
But theres still alot of work that needs to be finished.
Still need to order the fuel system, install the clutch, finish the piping obvisouly, figure out what im going to do about steering (pondering a thunderbird rack&pinion) and throw in the injectors and map sensor i have laying around. Thats all the big stuff imo.
Old Sep 2, 2013 | 01:06 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Well update! Made a last minute decision and picked this up over the weekend
Huge thanks to forum member Grifter757 (mr. Iroc boost)
Specs:
6.0 truck motor
Stock crank, eagle h-beam rods and je -22 pistons
Comp cams .598 .598 236/232 115 lsa cam
Arp mains, ported ls6 oil pump, ctsvr lifters and a few other goodies
I have some 317s at my house I need to have resurfaced to throw on.
I plan on some nice BT springs, stock rockers with trunion upgrade and some arp head studs. Should be a real nice combo when it comes together
Old Oct 10, 2013 | 06:24 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Little update:
Been slowly gathering some parts and putting the short block together
But first off some cleaning
Before:
After:
And I picked up some ls9 head gaskets and arp head studs
Installed:
To finish the motor I still need to
-swap the pan, windage tray, pick up tube and swap the oil pan
-order some valve springs and valve seals and put the heads on
-grab a ls6 intake and windage tray
and pretty much swap over all of the acc.'s. im trying to keep it as complete as possible to sell... or maybe use it for future project
Also ordered a 97' thunderbird rack. Sending that and the k member back tomorrow to get modified for the rack and have it changed to accept springs.
Still a long way from being finished unfortunately.
I need to put the clutch in, finally get the front end buttoned up, fuel system, and get some suspension pieces to handle it all.
Old Nov 24, 2013 | 01:13 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Time for another minor update!
Got the rack and pinion mounted and the k-member mounts welded on!
Now I just need to finish the steering linkage.
Heads bolted down
Still need to finish the valvetrain. I only put the v/c's on because I brought them earlier that day and wanted to see what they looked like
Also picked up a engine lift so I'll be able to swap out the motors soon
Old Nov 28, 2013 | 11:14 AM
86gn's Avatar
Car: 92 Vert
coming along good, takes time ..I have been building a harness for the last 2 weekends lol
Old Nov 29, 2013 | 03:59 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
agreed, but luckily..
PROGRESS!
...finally!
Motors out
Old centerforce dual friction clutch.. which lasted about a year before slipping.
Material left
New Mcleod dual disk
And i saw these on the classified section for a pretty darn good deal
Fifth gen brembos! Most important step in going fast... is stopping fast
Ill get some more pictures up later, but these things are massive.
Thats about it for today, im gonna start transferring over the oil pan, windage tray, etc. tomorrow
Old Nov 29, 2013 | 04:57 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Cool build. Subscribed!
Old Dec 1, 2013 | 10:54 PM
daniel92345z28's Avatar
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
u posted about using a thunderbird rack and pinion ,just curious with one u ended up using and how did u do it.
Old Dec 29, 2013 | 09:56 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Hey guys, sorry for the lack of updates
Car is coming along pretty quick ATM, so I'll go ahead and post a nice update hopefully followed by another in a week or so!
Ran into a few small problems while swapping everything over to the lq4.
Area I had my tensioner mounted on the ls1
And on the 6.0
So I went ahead and made a bracket that reached over to where that boss would/should be in the block
Clutch, timing cover and knock sensors on!
Steering = done! (For now)
Accessories done!
Ye ol ls1.... Waiting for it's next unknown home
I already went ahead and took off the valve covers and for over 200k miles, it's incredibly clean. I'll try to grab some pictures later.
And of course a few teasers! Enjoy!
Old Dec 29, 2013 | 10:18 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
By the next update, the motor should be installed and computer should have a base tune (hopefully, my tuner and I aren't seeing eye to eye) and I already sent out for my fuel system so that should be back in 3 or so weeks. In the meantime, I'll finish the motor which only needs pushrods, put the front suspension back together, and at least get the gauges hooked up along with all of the vacuum lines.
Old Jan 5, 2014 | 12:19 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Looks good man, I'm pretty much doing the same thing. Need to get motivation to finish the car! What are you doing for the down pipe?
Old Jan 9, 2014 | 06:20 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Probably will entertain the idea of what I can do the down pipe that came.
I'll probably end up using as much as I before it hits and v band it and go custom from there.
Also...
Motors in!
Harness is already hooked up, trans, front suspension, and the motor is almost finished.
Got the valvetrain finished, valve covers and coils all hooked up.
As for the steering...
Close, but it's still a fingers width away all the way around.
And as for the turning radius..
That is until the steering wheel hits it's stop. I obviously haven't gotten to driving around with it yet but hopefully soon.
All that should be left is the fuel system which I'm still waiting for, the computer to be based tuned, and all a little bit of the piping which I've already ordered the parts for.
Shouldn't be much longer boys!
Old Jan 9, 2014 | 07:18 PM
Chad85T/A's Avatar
Car: 85 T/A
Subscribed!
Old Jan 9, 2014 | 08:38 PM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Nice! Makes me want to hurry up and get the turbo on mine soon.
Old Feb 2, 2014 | 09:10 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Dum dum dum update!
Gettin buttoned up!
And valve covers, coils all back on!
Piping also done
Front bumper mockup
And then had to take it off as this came in
Pump mounted
That's about where I'm at right now. Hopefully by the end of the day I'll have the meth kit finished besides wiring. All that is left after that is to mount and run a vaccum block and the fuel system.... Still. Just waiting for it to come in which should be any day now
Old Feb 3, 2014 | 11:59 AM
86gn's Avatar
Car: 92 Vert
You work looks great! I run his alky kit on my grand national works great
Old Feb 3, 2014 | 08:18 PM
Z28FAST1's Avatar
Nice!!! Any pictures of clearance with the steering components?
Old Mar 7, 2014 | 08:47 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
I'll snap some tmr. Clearance I'd say is about a two finger widths from the manifold at worst.
Little update:
Fuel system finally came. Took about 2 or so months but the quality is awesome and it's really going to be a straight forward install. Besides that, I have some more wiring to run for the meth kit and also finish hooking up the vaccum block and I see no reason it can't be started and taken around for a quick spin! Expect a lot a big update and a lot of pictures today and Sunday!
Old Mar 8, 2014 | 10:33 AM
Warnd's Avatar
Car: 1992 z28
Really nice work so far. Would you mind posting some details about your fuel setup? Trying to figure out what I want to do with mine right now. Looks like you got all new lines which is something I want to look into. Any details you could provide would be much appreciated.
Old Mar 8, 2014 | 11:01 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
It is Lonnie's performance double pumper kit. Came with everything and it's a plug and play wiring harness which is awesome. It works for me since I have the whole fourth gen wiring for the gas tank along with a fourth gen tank.
I don't want to go too much into detail as he's not a sponsor iirc, but if you have any other questions pm me
Old Mar 10, 2014 | 08:51 PM
  #42
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Well good news and bad! It runs and drives which is great, did run into a couple problems though.
First was the thermostat didn't want to open at all to let any antifreeze in, after that was figured out I found a bad oil leak coming from the valve cover. Fixed that.
Then I went out for a little drive and the car still was over heating when cruising at low speeds or sitting still. Fans weren't coming on.
Troubled shot that a little tonight and figured out the trigger wire was wrong or something.
I took out a test light and even when temps were 220+ the power terminal which I believed was suppose to switch the fans on did nothing. Here is exactly how I was told to run the wires, the only difference is that I did the yellow trigger wire and left the green wires (optional a/c) alone.
Do I need to put the original relays back in ontop of the existing trigger wires to complete a circuit?
Any ideas or advice would be great as it would give me some direction to go in.
Old Mar 11, 2014 | 03:21 AM
  #43
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Cant wait to see some videos of it. How is the steering with the rack? Something I always wanted to do just never looked into on my old iroc.
Jay
Old Mar 11, 2014 | 03:31 AM
  #44
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Jay
The steering is actually pretty nice with my limited experience with the exception of the dump truck turning.
At the moment it's not really a big concern, but I plan on either getting a custom rack made with the same dimensions (or close to) however with X amount more throw to turn like stock.
Or I'm also talking to another member who may in the near feature gusset weld the aarm to shorten the steering brace to make up for some of the lost throw.
Right now the main concerns are:
1. Weld in the sub frame connectors
2. Finish wiring up the meth kit and finish install
3. Get the exhaust so it's at least coming from underneath the car. I really would like to get a full 4" all the way back to a cutout before the axel and then going with 3.5" over the axel.
4. Borrow or buy a set of drag radials
5. Alignment
That's all top priority so I'll be able to get the car tuned hopeful in the next couple weeks or so.
Old Mar 11, 2014 | 09:23 PM
  #45
Z28FAST1's Avatar
It's going to be a beast!! What injectors are you running(might have missed it)?
Old Mar 12, 2014 | 03:44 AM
  #46
Jay_rich's Avatar
Car: 1987 Z28
I would be interested to see how a 4" system fits. I ended up building a 3.5" Stainless with a Dynomax Straight through muffler for my current car. I was gonna go full 4" and it woulda been cheaper/easier for me to get. Just figured it would be a pita. I think I bought (4) 90's and (3) 45's and 4 feet straight and I still have I think 1 of each left. That got me all the way to the trans with a 45* shooting out to the passenger side. I think total I have like $350 for it all in stainless with the muffler.
All the bends were from diamond eye performance on summit and the 4' straight was from Jegs since summit only had 10' lengths.
Just to give you an idea of how cheap it can be done.
Jay
Old Mar 12, 2014 | 06:21 PM
  #47
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Siemens Deka 80's
Jay
Sounds good! I still havent decided if im going to do it myself yet or not. I got a quote to have the SFC installed for 100$, if I can get out of the shop for 350$ with the SFC and a downpipe so I can put the hood on then thats what im sure ill do.
Anyways
Well im lost,
Went to troubleshoot the wiring and couldnt get it. I went by this diagram
Also..
relay#1
86--power from ignition-shared
85--pcm signal--ground
30--battery +
87--+ to first fan
relay#2--farthest to the right
86--ignition power--shared
86--pcm ground--shared with relay#3
30--battery +
87--power to second fan--from 87a on 3rd relay( first fan ground wire)
relay#3
86--power from ignition( shared)
85--pcm signal for high speed
30--ground from first fan
87a--to 87 of second relay--series connection for low speed
87--frame ground or shared ground with second fan.
So I should be able to use each four pin relay using 87 to power the fans.. However I only got one fan running and also it wouldnt shut off with the key off.
C1 is 86 on the relay strangly which says its power from ignition? Shouldnt that be 87? The diagram shows that after its grounded, its fan power so it should be 87 I believe.
Also, B6 is looks the same as C1, but it IS 87 on the relay. The F*&^?
Also with all the relays in, I could not get the original fan wires to show up hot.
If anyone has any suggestions im more than open to hear them!
Old Mar 13, 2014 | 04:12 AM
  #48
Jay_rich's Avatar
Car: 1987 Z28
Its been a while since my last LS swap but for fan wiring I have always ran the contant/ignition/ground and the PCM as the trigger wire. (could be ground I cant remember if the pcm puts out a ground or a voltage for this).
But also for the not shutting off part. You can program the PCM to keep the fans running for up to 60-90 seconds after the ignition is off IIRC. I programmed my old C5 that way. Take a look at your PCM Fan settings. I assume you changed the temp settings if you went to a 160* stat?
Jay
Old Mar 13, 2014 | 01:03 PM
  #49
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Jay
The fans won't turn off as in the wires are still hot 5 minutes after shutting the ignition off. I'll see about using the grounds when I get home.
Any reason for the original fan wiring not seeing power? All I need is a trigger wire, and nothing seems to want to work.
Old Apr 5, 2014 | 10:29 PM
  #50
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Well FML.
Driving to work yesterday and hit what looked like a concrete block on I395 around a bend.
Destroyed the rack and pinion, which broke the k-member and severely bent a a-arm, which cracked the oil pan. Of course it was the first day I would of driven it to work and afterwards I was having the exhaust done. I figure it'll be about 1000$ setback.
