5.3 turbo build manifolds or headers?
Old May 7, 2013 | 08:32 PM
TNSS's Avatar
ok im doing a 5.3 turbo build. im to the point of putting the manifolds on. I was thinking in my head that I would just put them on backwards and run pipe to the turbo right in front of the motor. well after getting the motor in the manifolds hit the cross member so I have to put them on up side down. all that said it looks like the pipe could get close to the hood. how are you guys routing your manifolds and pipe? should I cut the ends off and weld on a v band so that the exit points to the front of the car or is there some really cheap headers that work? this is kind of a junk yard dog build so I don't want to go buy some high end headers. so all that said how do yall do it?
Old May 7, 2013 | 08:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 5.3 turbo build manifolds or headers?
Manifolds will support pretty high power. If you can vband them thats best idea imo for ease of assembly and seal
Just need to find right set of manifolds that will work flipped forward
Old May 7, 2013 | 09:12 PM
TNSS's Avatar
what manifolds seem to work? I have truck manifolds now off my L33 5.3 that came out of a truck, and they might work but are facing up like out the hood
Old May 7, 2013 | 10:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Not really sure, havent followed the lsx manifold craze but i think the truck mani's flipped forward dont work. Hit the k member or steering box.
Old May 7, 2013 | 10:28 PM
TNSS's Avatar
ya that is exactly what I have ran into. they fit flipped up side down but are pointed out the hood.
Old May 8, 2013 | 07:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I know this has been discussed here a lot, so doing a search should get you your answer. I just remembered reading somebody's turbo thread a couple days ago that discussed what manifolds. I believe that the general consensus is that the truck manifold works on one side, and an f-body manifold works on the other side. This isn't really enough to answer your question, but it should at least get you enough info to search out the answer.
Old May 9, 2013 | 08:19 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Getting er done on a budget and still a ballin car
http://ls1tech.com/forums/canadian-m...tt-tuning.html
Old May 9, 2013 | 05:15 PM
TNSS's Avatar
one day to late LOL. I found a used set of obx forward headers that I bought. should be here next week.
Old May 10, 2013 | 09:03 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Which headers are these?
Old May 10, 2013 | 01:05 PM
TNSS's Avatar
here is a link to them $450 new
http://www.racingpartdepot.com/servl...-LS1-to/Detail
Old May 10, 2013 | 02:02 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Had I know this I would of just built a 5.3 lol instead of making my own
Old May 21, 2013 | 11:52 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Those turbo manifolds are way too large primary and collector. I built a set of log manifolds.
Old May 29, 2013 | 05:51 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
if you could get someone to build you some or you could do it ill get more pics of mine and you could do it for your setup
anesthes
42
Oct 24, 2015 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 7, 2015 09:55 PM
