Something you guys with 700r4/4l60e and custom exhaust might want to look at
Old May 21, 2013 | 10:55 AM
Fastime's Avatar
Car: Z/28
Engine: LQ4
So I won an auction with Hawks 3rd gen (camarohawk) for a used crossmember for a 4l60e , but instead this is what showed up ...
So naturally I thought maybe the picture doesn't meet the description ...
The ONLY thing I have to do to make this cross member work is weld a plate on to capture the bolt on the mount .. its already sitting on the member I just can't do it up proper because the bolt is just shy by about 1 inch..
This is awesome because I was just going to modify the 4l60e cross member anyways .. This is going to work soooo much better ..
Old May 22, 2013 | 05:23 PM
Fastime's Avatar
Car: Z/28
Engine: LQ4
Re: Something you guys with 700r4/4l60e and custom exhaust might want to look at
Old May 22, 2013 | 09:31 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I dont understand? that cross member is made for the 4L60e tranny. Mine just bolted right in. Not sure why yours didnt??
Old May 22, 2013 | 09:44 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
He has a 700R4 according to his signature, but he modified a 4l60e crossmember to work with the 700R4.....or atleast that's what I get from it.
Old May 23, 2013 | 04:55 AM
Fastime's Avatar
Car: Z/28
Engine: LQ4
Yes Exactly.
Old May 23, 2013 | 09:43 PM
Pocket's Avatar
Car: 91 Trans Am
Looks nice
I would have chopped the extra material off the rear of the crossmember before sticking it back in there
Old Feb 12, 2016 | 09:59 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
bringing this back....how is this working out? I am looking to install one and was thinking of doing the same for a 700R4. However, I was just going to drill holes through the mounting sides to get access. Anyone done this?
Old Feb 18, 2016 | 06:56 PM
Pocket's Avatar
Car: 91 Trans Am
The frame rails arent parallel so drilling holes to shift it forward wont work. The simplest solution is to weld an extension like he posted. I prefer to build trans crossmembers from scratch because they never fit out of the box regardless of brand/chassis
Old Feb 19, 2016 | 08:49 PM
skinny z's Avatar
Originally Posted by Pocket
... I prefer to build trans crossmembers from scratch...
... and building the crossmember around the exhaust is easier than the other way around.
Old Feb 20, 2016 | 11:11 AM
Onion's Avatar
Can you try something like this instead?
Old Mar 8, 2016 | 07:38 AM
Car: 1982 Z-28
Engine: 383
To build my own is there special materials I need or just go to HD or Lowes and get some angle iron.
Old Mar 8, 2016 | 12:35 PM
toddoky's Avatar
Angle iron and commonly available plate is typically made from A36 steel (36ksi yield strength), which is less of a concern in your application than the material thickness, the geometric configuration of your design and the quality of your welds.
Old Mar 13, 2016 | 05:36 PM
Pocket's Avatar
Car: 91 Trans Am
Two 4' sticks of 2"x1/4" mild steel from lowes/HD is more than enough. Will have left overs for future projects and frame tabs. Weld sections together to make angle instead of sourcing it
Old May 27, 2016 | 01:19 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Originally Posted by Fastime
So when you did this, did you have to slot the new trans mount hole? I am doing the same, but when I did the test fit, the transmission was not in line with the hole in the crossmember.
I can't shift the transmission over, because it is already in contact with the new crossmember (I have already cut that portion off so it won't contact now.) Here's what mine looked like before I added the extra metal.
Old May 27, 2016 | 02:09 PM
Fastime's Avatar
Car: Z/28
Engine: LQ4
Yeah , I had to drill a new hole and cut the excess from between the new and old holes.
I wish I could show you a picture, but I already got rid of this setup for a T56.
Old May 28, 2016 | 08:47 AM
Lurbie's Avatar
Car: 89 Camaro
Did you also have contact between the fuel/brake lines and the crossmember? That's the only other thing that I have to modify for this to work; and that's not to bad, IMO, considering this wasn't built for a 700r4.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
midias
Aug 22, 2015 01:42 AM
Street Lethal
Aug 14, 2015 08:25 PM
