We wanted it to get a little more air...
Old May 23, 2013 | 08:44 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
There will be scoops under the front, on each side of the air dam.
Attached Thumbnails We wanted it to get a little more air...-custom-dual-intake.jpg   We wanted it to get a little more air...-400674_10151596549499114_1179120547_n.jpg   We wanted it to get a little more air...-217388_10151599480784114_266242705_n.jpg
Old May 23, 2013 | 10:50 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: We wanted it to get a little more air...
I like it! What do your scoops look like?
Old May 23, 2013 | 11:47 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Good question. We have run out of time before the Pontiacs in Pigeon Forge car show. The builder has taken all the measurements and will have them ready to install when we return from the trip. For now it is a cold air set up.
What we decided on was to be angled back slightly the way the factory air dam kind of curved back. Each would have a lip towards the outside edge to stop air from sliding past it. Whatever air hits the air center air dam without being forced up through the radiator will be forced into the intake. I assume they will be made of the same aluminum as the radiator shroud and either painted black or powder coated black chrome also.
Old May 24, 2013 | 12:04 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How is the MAF sensor going to be able to meter air?
Old May 24, 2013 | 12:26 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Be very careful in the rain. Ghettocruiser was running a low pickup and Hydro-Locked his engine going through a big puddle. Destroyed the engine.
Maybe you can work a setup where you get air down low at the track only.
Old May 24, 2013 | 08:55 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
SD tune....?
Old May 24, 2013 | 10:18 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
You can put a bypass filter on the intake so if you do go in the water then it will draw air through it and not draw in water. http://www.aemintakes.com/air_bypass_valve.htm
Old May 24, 2013 | 10:26 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
It does look cool, but for overall performance I think you'd be just fine with a single pipe to one side or the other.
85mm MAF + single pipe + nice air filter = all you need. Just drawing in the air at ambient temperature is the key.
Old May 24, 2013 | 11:26 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Just judging by the looks and numbers the car puts down, I doubt it sees wet weather, lol.
Old May 24, 2013 | 09:26 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
It is on a speed density tune and uses an IAT sensor.
Old May 24, 2013 | 09:29 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Thanks. I am a little worried about that but our filters are a good 18 inches off the ground and slightly forward of the opening. Plus they are in a compartment with the ability to drain off water. I'm hoping that is sufficient.
Old May 24, 2013 | 09:37 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
It doesn't see much wet weather at all. some though.
Old May 24, 2013 | 09:57 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
No benefit to dual ram air at 120 mph? Not being sarcastic, just wondering.
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
