Coil springs engine swap
Old Jul 23, 2013 | 02:58 PM
adamrivera94's Avatar
Okay so im swapping an ls1 in my 84 i just wanna know if i should change my coil springs in front? It was a stock v6 so will it be to soft?
If i do need to change them what would be the right way to go can i use truck coils? Or should i just get v8 springs off a camaro?
Old Jul 23, 2013 | 03:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
V6 front springs worked well in my LS1/T56 swap.
In the LS1/4L60E swap, I cut off half a coil from the V8 springs.
Old Jul 23, 2013 | 03:50 PM
Re: Coil springs engine swap
So just leave the v6 springs it wont bottom out?
Old Jul 23, 2013 | 03:51 PM
five7kid's Avatar
All I can tell you is mine didn't.
Old Jul 23, 2013 | 03:53 PM
Do you have a pic of it?
Old Jul 23, 2013 | 03:58 PM
five7kid's Avatar
This is probably the best pic I have to show the stance:
FWIW, the same springs in a 305/TH700 swap would bottom out.
Old Jul 23, 2013 | 04:01 PM
The ls1 is in the car in this pic?
Old Jul 24, 2013 | 07:25 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
When I did my first swap, I used v6 springs. I ended up with a stance with a little more wheel gap than five7kid
I ended up trimming two coils off the v6 springs.... One prolly would have been perfect.
The drop will depend on the age and mileage of the springs
Old Jul 24, 2013 | 11:34 AM
five7kid's Avatar
Yes. LS1, T56, AC, PS, etc. I took this pic when hauling it to the shop for exhaust install.
Those are 15" rims, I later put 16x8 rims on with 245-45x16 4th gen take-off tires (from back in 2002). Afraid I don't have a good shot with them on.
Old Jul 25, 2013 | 06:45 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Taller front springs with a lower rate are good for dragstrip launching. I'm wanting a canyon carver so I'm going with cut V8 springs up front. Most all-iron SBC third gens go with Moog 5662s, so I'm thinking 5660s for me because aluminum heads, plastic intake and no a/c. I'll probably cut one full coil before installing. New front springs are only $47 / pr. So why not?
Old Aug 17, 2013 | 05:23 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I have stock Iroc coils up front that I cut 1/2 coil. Ride height is flat/level and the spring rate is perfect for going fast through corners. I´m having an LS2 with a T56 in my car.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 25, 2015 07:34 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
