Wiring Harness..Halfway Done..HELP!!!
Old Aug 6, 2013 | 10:35 AM
jahblah's Avatar
Car: 87' Firebird Formula
I finished the 3rd Gen Wiring harness prep last night. Pocket's write-up REALLY helped. I was pretty reluctant at first due to the fear of messing up something or being overwhelmed by the wiring but once you start cutting the "commons", your pretty much good to go. I have everything all nice and neat.
Now, to start on the LT! harness. Pocket's write-up for that is a bit confusing. Especially when I saw that I had to disassemble the PCM connectors. SCARY!!! I'm getting down to the nittly gritty and the wiring harness is about the only thing holding me up from finishing.
Is there an easier route that anyone has taken??
Old Aug 6, 2013 | 11:32 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Wiring Harness..Halfway Done..HELP!!!
If the lt1 harness and PCM are from the same vehicle, it helps to label the wires with the connector color and pin location before dis-assembling the PCM connectors. Saves a little time when re-assembling.
Old Aug 6, 2013 | 09:03 PM
jahblah's Avatar
yes, they are from the same vehicle. i can see how that would help some. any other suggestions?? any shortcuts anyone took?
Old Aug 6, 2013 | 09:33 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Do you really want to take a "shortcut" when it comes to wiring?
Old Aug 7, 2013 | 10:08 AM
jahblah's Avatar
lol guess not. i just wish i could find an easier explanation to this. I know there are countless write-ups for this but I do not understand what A7 and G3 pins mean. Ive stripped my LT1 harness of the plastic and some tape. I have 7 tabs open, each on a thirdgen.org thread about wiring the harness together. I'm trying.
Old Aug 7, 2013 | 10:53 AM
jahblah's Avatar
found something. this looks pretty simplified and usable...
http://www.camaroz28.com/forums/3rd-...ite-up-474185/
Old Aug 7, 2013 | 11:32 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
This is a diagram I have saved from one of pockets threads. If you look at the C207 connector closely(one under the dash near factory PCM) the clear connector has each wire pin location marked with its own letter. This photo shows the pin locations in a fashion like the game battle ship. You can match your C100 plug in the same orientation as in this picture and the "a7" and such will become clear.
Old Aug 11, 2013 | 07:11 PM
jahblah's Avatar
AWESOME!!! thanks. I had took a couple of days off from the harness to relieve the stress from it. I'm back at it right now. Deloomed and taped, commons cut. About ready to disassemble the PCM connectors now. NO FEAR!!!!!! GRRRRR!!!!!!!!!!
Plus the football season has started!!!
Old Aug 12, 2013 | 10:51 AM
jahblah's Avatar
Okay, i have completely disassembled the LT1 PCM connectors on down the harness. Individually wrapped everything nice and neatly.
I was using the pictures in this thread as reference but the they no longer will load. I've restarted my computer and all...just says "photobucket".
https://www.thirdgen.org/forums/ltx-...rt-finish.html
What do I do now? Begin repinning the colored PCM connectors?
Old Aug 12, 2013 | 11:20 AM
jahblah's Avatar
I was just reading an LS swap harness thread pocket wrote. Is it comparable to the LT1 swap harness? Was I not suppose to cut the Pink wire that ran to all the injectors??? It had commons in it! HELP!!!!!!!!!
Old Aug 12, 2013 | 11:58 PM
jahblah's Avatar
anybody?? is it because i'm a patriots fan?
Old Aug 13, 2013 | 12:20 AM
jahblah's Avatar
I think I have found my problem..I disassembled the PCM connectors without labeling them so I don't know what wires go with what numbers. Any help with reassembling them?
Old Aug 13, 2013 | 12:27 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Stay calm i like the Pats when Tom Brady's not pussin out in the pocket. Just make sure the injectors have a 12v switched source and your one step closer man.
Old Aug 13, 2013 | 12:29 AM
89rs454's Avatar
Car: 1989 SS
You seem very sloppy with your swap, um don't you have diagrams and stuff to help you out, or are you doing this wire by wire?
Old Aug 13, 2013 | 09:42 AM
Pocket's Avatar
Car: 91 Trans Am
Step one is relax. This is connect the dots not neuroscience
Photobucket only alows so much bandwidth per month for free users like me. When a lot of people read the threads, bandwidth is maxed out and the pics go down for a spell. It resets mid month so don't worry, the pics will come back
The LS1 harness build is the same with a handful of different connectors. Don't fret over the injector commons, it just means you'll have to splice them back together later. A bit easier if they remain together
I don't recommend labeling each pin as they are removed because a lot won't be reused and if you mislabel one, chances are it won't get caught until you're finishing up. It's much easier to properly label each circuit with the loose connector by itself
Old Aug 13, 2013 | 11:01 AM
jahblah's Avatar
Well, sloppy I guess. No diagrams, just threads to go off of. Wire by wire. And I was extremely afraid that I have trashed my harness and would have to find another. I was at the hair pulling stage. Just wish I knew how this stuff goes back.
Gotcha. So how did you know which location to put the pins back into? I thought the write-ups would help but I realized the connectors are numerically labeled 1-32 and the diagrams that people are displaying are alphabetically labeled and colors. I tried the colors game as well but almost none matched up to what I was reading. I'll upload some pictures to show where I am in this wiring thing.
Old Aug 14, 2013 | 05:34 PM
Pocket's Avatar
Car: 91 Trans Am
Color associations with each connector is the fastest
EX, MAF is pnk yel and blk. That's 12v ign, signal to the PCM and grd respectively. Some colors change over the years like the low ref may be ppl or blk, etc. it will be the same changes for the entire harness
Old Aug 16, 2013 | 08:51 PM
89rs454's Avatar
Car: 1989 SS
Well good luck man, I was **** faced when i last posted, i'm surprised i got that much out. Um Cheers.......
Old Aug 16, 2013 | 09:05 PM
3GZJerry's Avatar
Car: 1990 IRoc Z
Go Dolphins!!
Old Aug 16, 2013 | 09:09 PM
jahblah's Avatar
This attachment shows the organization and separation according to PCM connectors and what was removed from them.
Old Aug 16, 2013 | 09:11 PM
jahblah's Avatar
Blue, Black, and Red PCM connectors and the corresponding wires that were remolved from each
Attached Thumbnails Wiring Harness..Halfway Done..HELP!!!-photo-6-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-7-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-9-.jpg
Old Aug 16, 2013 | 09:15 PM
jahblah's Avatar
White PCM connector, other plugs and wires, and random wires.
Attached Thumbnails Wiring Harness..Halfway Done..HELP!!!-photo-10-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-8-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-11-.jpg
Old Aug 16, 2013 | 09:18 PM
jahblah's Avatar
The thirdgen stuff..C100, C207 (i think) and other connectors and such..
Attached Thumbnails Wiring Harness..Halfway Done..HELP!!!-photo-14-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-15-.jpg   Wiring Harness..Halfway Done..HELP!!!-photo-18-.jpg
Old Aug 16, 2013 | 09:51 PM
jahblah's Avatar
So, as long as the pins go to the appropriate connector, it doesn't matter which number (0-32) i insert the pin into??
Lol thanks
Originally Posted by 3GZJerry
Go Dolphins!!
Good luck to you Dolphins!!!
Old Aug 17, 2013 | 05:49 AM
Pocket's Avatar
Car: 91 Trans Am
So, as long as the pins go to the appropriate connector, it doesn't matter which number (0-32) i insert the pin !!
It absolutely matters. The point was to identify each wire based on color from each connector
Old Aug 17, 2013 | 11:20 AM
jahblah's Avatar
So how do you know which number they go in? that's kind of my only hold up...I tried to do everything as you pictured, didn't think labeling would have been so vital to my progress. LESSON LEARNED!!!!
Old Aug 18, 2013 | 05:53 AM
Pocket's Avatar
Car: 91 Trans Am
http://www.lt1swap.com/lt1_pcm_pinout.htm
Google any lt1 pinout or check out that link
Old Aug 18, 2013 | 09:45 PM
jahblah's Avatar
YEEEESSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! EXACTLY what I needed!!!!!!!!!!!!!!!!!!!!!! Thank you sooooooooooooooo much!!!!!!!!!!!!!!! Going to start on it ASAP!!!!!!!!! Will update..
Old Aug 19, 2013 | 10:21 PM
jahblah's Avatar
Okay, I have about 90-95% of my PCM connectors repined. Where is this CKP SIGNAL wire? I have searched my remaining scrap of wires and don't see any such. It's supposed to be a yellow wire. Any ideas?
Old Aug 20, 2013 | 07:03 AM
Pocket's Avatar
Car: 91 Trans Am
Same connector as the MAF and tees into the opti circuit. It's a 96-97 only connector. 94-95 harnesses/pcms don't use the crank circuit
Old Aug 29, 2013 | 02:01 AM
jahblah's Avatar
Okay, great to know. So that's behind me. I had took some time off from this wiring headache. Back to work i guess. Couple questions...
1) I have 1 transmission wire left over from repinning the connectors. Its white. I followed the pin chart and didn't see it, any ideas?
2)Whats an ALDL?
3) Do I begin fusing the wiring harness' next?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
