Trailblazer manifolds and how they fit a 3rd gen.
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
Pick up some trailblazer V8 manifolds on the cheap at the pick n pull the other day. They actually fit pretty well, maybe not quite as good as the 4th gen manifolds but they are useable. I like them better than the 4th gen because they don't have any O2 ports, EGR ports or bosses and are a better looking manifold.
here's some pics.
driver side
this tab that the heat shield bolts too must be cut off.
you can see the tab a little better in this pic.
Passenger side
here's some pics.
driver side
Passenger side
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Trailblazer manifolds and how they fit a 3rd gen.
Damn those are almost perfect!
Transmission: 4L80E/4L80E
Interesting. I don't believe I've heard of anyone trying them before.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
wow i wonder how they perform.seem to fit nicely with small modding.
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
The passenger side outlet I.D. Is the same size as the passenger fbody manifold basically 2.25" The driverside trailblazer manifold outlet I.D. is 2.18 vs the fbody's 2.25. The primaries are the same. The overall length seems better on the trailblazer manifolds, so they may help with torque a little more.
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Now it is time to look into trailblazer headers.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Egr stuff is very rarely used on swaps, and is a cleaner look to not have it, or fab block-off plates to get rid of it.
No O2 ports allows you to weld in a bung in the pipe just after the manifold, and gives you endless placement options, instead of having to put it where factory intended.
Some swaps are tuned without any O2 sensors at all, although not a common scenario, it would be absolutely perfect for that.
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
Cool with another option/way to go. A good heat paint or maybe some spray on ceramic coating and they will look really good too :-)
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
I'm gonna get some more pics and update this a little better when I get some free time.
The lack of O2 and EGR is great for a carb conversion.
Pacesetter makes a set of 1 3/4 long tubes for a trailblazer, uncoated for sub $300. I have no clue if they'll fit a Camaro or not.
ambainb
Apr 25, 2016 09:21 PM
