LT1/4L60E combo
Old Aug 20, 2013 | 07:45 PM
elesone's Avatar
LT1/4L60E combo
I need info on some equipment that is available to me. It's an LT1 and a 4L60E. The PCM/ECM has 16214399 BSTP and no harness. The only info I found is the PCM is a 1996. No find on the BBC BSTP.
Can anyone help with more info? Like what car(s) it's out off, OBD2 (I think) and anything else. Please and thank you.
BTW-This forum is more informative than any other one I lurk on, including non-third gen info.
Old Aug 23, 2013 | 02:31 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: LT1/4L60E combo
Originally Posted by elesone
PCM/ECM has 16214399 BSTP The only info I found is the PCM is a 1996.
You don't say what you plan to do with it but it will need reprogramming ("custom " tune) to remove the security function
and once you get a custom tune it makes no difference " what" it was setup for originally because it can be programmed to suit any LT1 engine you want.
In any case, most convert 96/97 OBDII PCM's back to 94/95 OBDI for ease of install and cheaper tuning
Old Aug 23, 2013 | 07:22 AM
elesone's Avatar
Re: LT1/4L60E combo
Well you're right about going OBD1/7730. The plan is to transplant it into a gen3 or a hotrod. The reason for finding where it came from is, too many sellers advertise it came out of a vette just to ask for more cash. So it's mostly to prove a point. Who knows, maybe the engine was replaced with a substitution.
Thanks again.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
