5.3 PCM
Old Sep 25, 2013 | 02:52 PM
adamrivera94's Avatar
5.3 PCM
Okay so I need to buy a PCM my motor is a 01 Tahoe 5.3 will the PCM off an 01 4.8 tahoe still work on mine?
Old Sep 26, 2013 | 11:41 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 PCM
No stock PCM will directly work, all need a reflash to turn off vats and other things. Since its being reflashed, what tune is in there from the start makes no difference
I use cheap s10/van pcms with the 4.3 v6 for that very reason
Old Sep 26, 2013 | 12:15 PM
Re: 5.3 PCM
Okay so I got my pcm yesterday my question now is will my car start before I get the reflag or do I née to get it reflagged what need to be done to the pcm for the car to start and run like a champ
Old Sep 26, 2013 | 12:51 PM
86gn's Avatar
Car: 92 Vert
Re: 5.3 PCM
If the vats is on the car will not start and run,
Old Sep 26, 2013 | 01:27 PM
Re: 5.3 PCM
So my car won't start at all without the reflash?
Old Sep 26, 2013 | 02:12 PM
86gn's Avatar
Car: 92 Vert
Re: 5.3 PCM
VATS is part of the security in the pcm and has to be disabled b4 it will start, if the vats is turned off the car will run but may run poorly until you get some kind of tune on it for your application. If you don't have a place local you can send it off and have the VATS disabled and a base tune put on it, they will want to know all the details of your build to get something to get yya started.
ZZ3Astro
Aug 13, 2019 12:57 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
