Will this work?
Old Oct 8, 2013 | 12:17 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Will this work?
lm7 and t56 are going in question is will an auto ecu from an fbody work with the t56?
Old Oct 8, 2013 | 12:58 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Will this work?
I ran my 99 LS1 w/T56 using an Auto PCM. I believe you have to flash a T56 stock tune on it to start. Maybe not tho...there should be some documented changes that you can make to the auto PCM so it works.
Mine was fine, but when I went for a tune I purchased a 2002 LS1/T56 PCM to make things work better (per recommendation from my tuner).
J.
Old Oct 8, 2013 | 01:42 PM
WTR388's Avatar
Car: 87 Trans Am
Re: Will this work?
I was pretty sure once it's flashed you're good to go... I hope so because my ECU is from an auto and I'm going T56 as well
Old Oct 8, 2013 | 02:27 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Will this work?
contact Rodney "Spareecm" on ebay, he knows what hes doing and can flash it for your application for a very reasonable price.
Old Oct 8, 2013 | 06:54 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Will this work?
Unflashed but remanned ECMs from Rock are pretty reasonable- tho the core charge is hefty.
Old Oct 8, 2013 | 06:57 PM
Re: Will this work?
If you need an ecm I have 2 0411's for 60 shipped each... no core haha
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
