Cam Question in 5.3l
Old Dec 14, 2013 | 03:22 PM
Cole Curtis's Avatar
Car: 82 camaro z28
Engine: 305 crossfire...soon to be 5.3l ls1
Transmission: 2004r :( I need a new one
Axle/Gears: 3.43 10 bolt I think
I purchased a 5.3l block for my swap into an 82 camaro and the guy "threw" in a ls1 cam for free. My question is how will this cam work in 5.3l and is it worth putting in or getting a custom grind. I've looked up the part and grind # to no avail. I know a little bit about cams but not that much and I find it weird the intake and exhaust are the same? and what kind of hp gains could I expect over a stock cam or another custom grind?
Specs: part# 54-000-11 grind#: 13117r/13117r
gross valve lift: I-.598 E-.598
Duration @ .006 Tappet lift 275 275
duration @ .050 I- 226 E-226
lobe lift I-.3520 E-same
Lobe separation 113.0
Old Dec 15, 2013 | 01:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Cam Question in 5.3l
I moved your post in the Tech/General Engine forum to this forum.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
