First stage for lsx swap?
Old Feb 11, 2014 | 01:16 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
So someday soon (I hope) I am going to do a lsx swap but I am wondering what I should start with. I was thinking a t56 swap first would this work?? My t5 is starting to grind in third and I know the syncros are on their way out . I was quoted 700 dollars to put new syncros and instaed of doing that could I just go t56. My car has a 5.7l vortec in it now could I make this work so in the future I could just swap the lsx in without removing the trans again?
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: First stage for lsx swap?
If not where would the best place to begin be?
Old Feb 11, 2014 | 03:57 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
To run a T56 on your stock 5.7 you will need a LT1 T56, so if going LS it will be more BS than its worth. IIRC. Pretty sure you will need a conversion bell housing or Bell housing spacer if using a LS T56 on a SBC.
Good luck!
Jay
Old Feb 11, 2014 | 11:42 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
well what would be a good first step or would I need to do it all at once?
Old Feb 11, 2014 | 01:28 PM
Pocket's Avatar
Car: 91 Trans Am
I'd deal with the grind and do the t56 swap with the LSx swap. Lt1 and ls1 t56's are different, but can be converted for around $600
Mid plate, input shaft and bell are about $200 each, plus hydraulics
Old Feb 11, 2014 | 03:28 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Unfortunately this swap is not easy to do in segments. Look at it as a platform and make the switch fully, or dont. Mixing and matching different components compounds the difficulty so its best left for those who have swap experience under their belt.
Good news is the costs have come down on the engine side of things. Bad news is t56 costs have stayed every bit as high if not higher than they used to be. Supply and demand issues mostly as almost everyone wants one.
But if your crafty, you can pre prep 90% of the swap before you start tearing things out of your car which can make the install go down quite quickly. Have fun
Old Feb 11, 2014 | 08:30 PM
WTR388's Avatar
Car: 87 Trans Am
Take pocket and cams advice. Save up, take your time buying parts when you find them for good prices.
My 305 with t5 has some minor issues. I get vapour lock when stuck in gridlock on the hottest days, valve seals leak and my clutch slips a tad.
I have an ls1 now, taking my time cleaning it up while it's oh of the car. Found an lt1 t56, $1400 that isn't high mile or from a car that burnt (dude wanted $1800 for that one, another guy wanted $1800 for one with over 190,000 miles) just pay attention to the market. Found a bell housing for $200 with a slave. Online they are $250, plus I have to ship, cross border, pay duties, taxes and a bad exchange rate.
Junkyards are good, you can find swap parts in there for cheap.
Be patient, find decent prices (this is NOT a cheap swap... Ill be lucky to be under $5500) and drive the **** out of your current set up. It will make it worth it. Figure out everything you can, do all the work you can before you start the actual swap. My wiring will be 99% done before I start. I will have all of my fueling parts ready to go, I'll have any special tools I might need, etc so when it comes time to do the swap, I'll only have a few minor set backs (always happens) but it won't stop the project.
Every time you do a change, there is time spent after tweaking things. I would rather drive the car, do the swap and then tinker instead of do a part of a swap, spend more money than you need and waste time and money messing around with something that isn't permanent.
Old Feb 12, 2014 | 01:26 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Thanks for all the great advice guys!!!! I will just drive the hell out of what I have now until something major quits then I will do the swap
Old Feb 12, 2014 | 08:11 AM
V8SC1987's Avatar
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
Where are you located in Tennessee?
Old Feb 12, 2014 | 08:17 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
One thing definitely worthy of doing while your driving the %#$@ out of the current config is to find your donor engine/trans set up. If you shop hard you can get some good savings but it typically takes a lot of persistence to find the right deals. Good luck
Old Feb 12, 2014 | 10:54 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Im in chattanooga just two hours from nashville
Old Feb 13, 2014 | 04:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
2 birds with one stone:
http://paceperformance.com/i-1590875...m-t-combo.html
Problem solved...
Old Feb 13, 2014 | 05:45 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I like this package. Thats actually not a bad deal for all you get. Plus think of the time saved alone chasing down all those parts/deals.... and then no assurance that everything will work as you hope... Used parts get a 30 feet or 30 second warranty. Sometimes its best to stroke cheque for something like this instead and then get straight to work on the install!! Verrrrrrry quickly you can build a worry free LS swapped badass
But chasing parts is so fun, and half of us love the process as much as the end result so its not for everyone.
Maybe throw that in the sticky somewhere? Update it with engine packages/deals currently available?
Old Feb 14, 2014 | 02:15 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
would finding a good disc brake posi rear end from a fourth gen camaro or firebird work on my t5 then later be reused on the t56?
Old Feb 14, 2014 | 02:37 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
4th gen diffs are 4" wider but the suspension mounts are exactly the same, some brake differences though, nothing major, very common swap
Old Feb 17, 2014 | 04:52 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
would you reccommend me doing the swap or just wait though?
Old Feb 17, 2014 | 05:10 PM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
You will have a lot more fun with your current setup if you get some lower rear gears (like 3.23-3.73s).
Weather you get a whole 4th gen rear end or just re-gear your current one.
4th gens have a nicer torsen limited slip unit, that most would say is better than a 3rd gen auburn unit. Keep in mind if your running stock 3rd gen wheels the rear ones will stick out 2" on either side if you install a 4th gen rear end. If you run 4th gen wheels they work without adapters though, which is nice.
Bottom line is yes, upgrade the rear end before swapping to LS is totally worth it.
Old Feb 17, 2014 | 05:17 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Alright Thanks man and I do plan on running 4th rims. Could I do the swap or should I go to a Shop?
Old Feb 17, 2014 | 05:37 PM
Engine: 5.3 LM4
Transmission: 4L65E
The average joe can usually swap a whole rear end but its a bit of a learning curve to properly set up new gears.
But remember when swapping a whole rear end, you need to worry about hooking up brake lines and cables, and if you have drums now, youd be swapping to disc with a 4th gen posi rear end.
I have a 3rd gen posi rear from an 85 TA so I havent actually swapped a 4th gen rear into a 3rd gen, but I think its a "bolt-in" swap for the most part.
Old Feb 17, 2014 | 07:25 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Ok thanks man
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
