F-body LT1 AC delete pulley problems
Old Mar 28, 2014 | 08:26 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Transmission: 700R4-
Axle/Gears: 3:27/3:73
I had the correct AC delete pulley for my car, but it walked off before I bolted it on. I've since purchased two more which were both incorrect. The first, correct one I got had a smaller pulley and three threadless mounting holes, while the two incorrect ones had a larger pulley and three threaded mounting holes. Can anyone tell me the part number for the correct one, and possibly a guaranteed source for it?
Old Mar 28, 2014 | 08:57 PM
kcaalarcon's Avatar
Re: F-body LT1 AC delete pulley problems
I got mine from napa. It was the same size pulley as stock ac but the mounting holes where threaded so I just drilled out the threads. I don't no the part number so I can't help you very much
Old Mar 28, 2014 | 09:01 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Thanks, but the correct one is so much nicer, and does actually exist.
Old Apr 1, 2014 | 07:02 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Nobody?
Old Apr 2, 2014 | 05:59 PM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
I have a new GM one somewhere in the shop, I'll see if I can find it next time I'm down there, I ended up using a relocation kit & keeping the AC so I didn't use it.
Old Apr 2, 2014 | 09:21 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Thanks, that would be awesome if you can find it. I purchased the Vette bracket but it's gonna take some time to get all the accessories together.
Old Apr 9, 2014 | 12:28 PM
88monteSS's Avatar
Engine: LT1/454/LS4
Finally had time to get down there yesterday. Started thinking mine had grown legs too, found the box right away in with the box of other LT1 parts, but the pulley itself was nowhere to be found. Finally found it lurking in the box the relocation kit came in. It's GM part #10115875
If you can't find one I might be persuaded to come off of mine, chances are the next LT1 I do will get a/c (if I even do an LT1 for the car, I'm leaning towards it just because I have so many parts for them laying around.), but I've been keeping it around just in case.
I thought about doing the Vette bracket, but it was cheaper IMO to spend the $ on the relocation kit & reuse the 4th gen accessories (which I already had) than it would've been to pick up the vette bracket & track down all the vette accessories. I know there's some that'll say just notch the crossmember, but I wasn't comfortable doing that, so I didn't consider it an option for me.
Old Apr 13, 2014 | 07:52 AM
nickdiesel's Avatar
Car: 1988 Camaro Convertible
Wondering if I could persuade you to come off of it. I need one bad and can't find any that aren't knock offs.
Old Apr 14, 2014 | 09:56 AM
nickdiesel's Avatar
Sorry read that wrong thought tnitz was all set if you guys see any other OEM let me know thanks
Old Apr 15, 2014 | 01:27 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Yeah, so what kind of persuasion are we looking for?
Old Apr 15, 2014 | 03:48 PM
88monteSS's Avatar
Engine: LT1/454/LS4
supposedly these guys have it: http://parts.nalleygmc.com/products/.../10115875.html
If not, pm me an offer.
Old Apr 16, 2014 | 01:12 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Pm sent
italiano67
Dec 11, 2016 09:21 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
sreZ28
Aug 14, 2015 07:48 PM
