4th gen tank help
Old May 25, 2014 | 02:46 AM
Gecz28's Avatar
Car: 88 iroc vert
4th gen tank help
hey guys, im looking for some help on how i need to plumb my ls1 with the 98 tank. im getting rid of the evap stuff so would this setup work...???
1 feed
2 vent
3 return?
4 vent(to purge tank now??)
and then do this setup??
Originally Posted by Rich92 RS
Fuel Lines:
3rd gen hardline used from the engine bay to tee fitting. Tee fitting rearward is 4th gen lines, and custom nylon braided line.
Stock 3rd gen hardline, connects to tee fitting. From there the ls1’s return line, and fuel filter/feed line. A short line was needed to connect the plastic feed line coming off the tank, to where the fuel filter is located.
Old May 27, 2014 | 07:48 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 4th gen tank help
If you are dumping EVAP and already have one vent line then cap #4
You need to have a regulator in the tank to use the tee fitting system shown. 99+ V8 cars did, Im not sure about the 98 steel tank. Pull the sender and look
If it doesnt have a regulator, use the C5 filter/regulator
Old May 27, 2014 | 02:35 PM
Gecz28's Avatar
Car: 88 iroc vert
heres the one listed for 98s from autozone, looks different than the 99+,
so im guessing i need the this c5 filter
Old May 28, 2014 | 06:59 AM
Pocket's Avatar
Car: 91 Trans Am
http://m.ls1tech.com/forums/showthread.php?t=443056&styleid=27
According to that, 98's had an intank regulator, so use the tee style fuel lines
Remember, all fbody ls1s were returnless systems, v6's we're return style. If the tank was from a v6, the regulator will not be there and the C5 filter/regulator is required
Also, the neck is longer for 4th gen tanks. Not a problem on plastic tanks, just trim the rubber hose. Steel tanks require splicing the neck
Old May 28, 2014 | 06:05 PM
Gecz28's Avatar
Car: 88 iroc vert
i just look at my 4th gen lines and it does have the factory 't' in it already lol
i pulled the tank and didnt even think about what the 4th gen lines look like until i pulled them today
im an idiot
Old May 28, 2014 | 08:25 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Don't mean to hijack this thread, but since we are talking about pressure regulators. Just a curious question, is it possible to use the stock FPR on a TPI with these tanks??
Old May 30, 2014 | 09:34 AM
Pocket's Avatar
Car: 91 Trans Am
Use a v6 sender or gut the ls1 regulator, then use a supply and return line
Old May 30, 2014 | 09:45 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I was gonna use the 98 metal tank from my donor car but I did not want to deal with the metal filler neck. I used the 99 plastic tank. Much easier.
Old May 30, 2014 | 02:11 PM
Pocket's Avatar
Car: 91 Trans Am
A removable neck makes removal/install of the tank hours easier
Lower axle to full droop, pull both pan hard bars, out she comes. To add insult to injury, the fuel line connections are on top, so cutting the access hole is acceptable. It also has a much larger hole for the sender, so multiple pumps fit without divine intervention
Twin pumps in a 3rd gen tank are a feat
Old Jun 11, 2014 | 06:29 AM
Gecz28's Avatar
Car: 88 iroc vert
what do you use to cap it? or can i just make that another vent?
Old Jun 11, 2014 | 11:28 AM
Pocket's Avatar
Car: 91 Trans Am
Vacuum caps from any parts store work. Put a breather on the end if you want. A second vent won't hurt anything
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
