Help a confused newbie out.
Old Jul 24, 2014 | 03:18 PM
deth0168's Avatar
http://www.superchevy.com/how-to/pro...ngine-buildup/
I was wondering what you guys thought of this build and if you think that their numbers are accurate. Also reading the lift of the hot cam and what I can find as the max lift of the head they don't explain how they got those two to mesh up. Also no mention of rocker ratio either. I am interested in doing this as a build but would like to keep it injected.
Old Jul 25, 2014 | 06:54 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Help a confused newbie out.
Your first post is that?
Do you already have an LQ4 swapped into a third gen?
If not, then you're starting on the wrong foot.
Figuring out the final combo for power is not the first step, though having a goal in mind is necessary.
Getting any LSx running in an any swap seems to be the most difficult part, especially when there's no ready-made tune for the exact parts combo.
Once the LQ4 is in, then get it dyno tuned for the headers, then change the heads, then get it dyno tuned, then change the cam, etc.
Also, I didn't read much of that build, but that was a carb-style intake, so they probably cammed it for a carb. A build like that, with LS3 heads, a FAST LSXR intake, and an EFI cam can easily see 500 HP, and 550 isn't out of the question.
But 550 HP for less money, with better road manners and half again the MPG made me choose a turbo on a stock 4.8L version. Just something to think about. And do you have smog testing? If so, then any cam that'll get that 6.0L to 550 HP isn't going to work out.
Old Jul 25, 2014 | 07:25 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
... welcome to TGO!
Not sure why it matters that that was his first post.
Old Jul 25, 2014 | 08:13 AM
cosmick's Avatar
Originally Posted by RedLeader289
... welcome to TGO!
It could've gone better on LS1tech.com
Why nothing about the car itself?
Old Jul 25, 2014 | 08:27 AM
Car: 1983 Z28
Maybe, who knows.
Maybe he doesn't have the car yet and this is just dream research or something, idk.
Old Jul 25, 2014 | 09:09 AM
deth0168's Avatar
First off I would like to apologize for spending the last couple of weeks lurking this site trying to soak up as much info as I can so that I would not be asking any stupid questions. Now I see that all I did was waste my time seeing as how if you don't have hundreds of posts all you are is trash.
Yes this is a dream build right now until I sell my Rzr. I am hoping to find a car to replace the 85 Iroc I had when I was 19.
Also I have no plans to buy a junk yard motor to install only to change components later. I am planning on a rebuild with hopefully all the right parts to build once. I am not a fan of doing things twice just to try and save a few dollars.
Old Jul 25, 2014 | 09:13 AM
Car: 1983 Z28
Ask away, sir! That's what the site is for. Some people will flame you but there's that on all forums unfortunately. Quite a few members don't even have thirdgens on this forum. So whether it's a dream or reality get all the info you want so that when you do replace that '85 you can dive right in!
Old Jul 25, 2014 | 09:14 AM
Car: 1983 Z28
Post counts don't matter, they aren't an accurate portrayal of knowledge, so don't fret on that.
deth0168's Avatar
Old Jul 25, 2014 | 10:32 AM
makingPAIN's Avatar
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
hey I dreamed for four years looking at my firebird in my garage now I am smoldering the tires everyday in it with my new engine and tranny dream on man that's how it all starts
Old Jul 28, 2014 | 07:59 PM
deth0168's Avatar
I guess my plans have changed from an LS conversion to bbc. My stepdad has a 402 in the shop that pretty much just needs assembled and he is letting my have it. Now to search for a cam.
Galaxie500XL
Feb 1, 2020 04:53 AM
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
mfp189
Sep 27, 2015 09:25 AM
bubbaz28
Sep 18, 2015 02:09 PM
