305 to lt1 help
Car: 82' Z28 Crossfire
Transmission: Turbo 350
305 to lt1 help
I'm planning just for now to pull injection off lt1 so I don't have to tinker with wiring and put an intake / carb on it. Will my 91 305 intake and headers fit the lt1? Idk the difference in the heads
Transmission: T-5, TH350, T-5
Re: 305 to lt1 help
Third gen headers are mandatory, they will bolt up, you'll want to use ones with 1 3/4 primaries to 'swallow' the exhaust port. No your intake will not work. There are carb'd LT1 intakes out there. http://www.summitracing.com/parts/nal-24502592 To be honest, just build a gen 1 SBC and have more choices heads, not hassle with coolant system changes and so on. Otherwise I'd keep the sequential fuel injection, it's worth it on an LT.
Re: 305 to lt1 help
Just a little background info. The 305 had almost 300k on it with way too big of a cam and started knocking so I'm looking to get this thing running quick.
If you still need to buy a stall and have the factory one, you can run it and keep the stock cam for now. It moves my wagon around pretty well. Then save till you can really build an engine. Or just find a cheap 305 and waste as little money as possible. Save and build later, it works out so much better that way. That's why so many suggest that.
Re: 305 to lt1 help
Plausible way to do it. If the LT is close to free it may work out well. I won't talk you out of it but I wouldn't bother spending money on something temporary. Don't get me wrong, my LT1 is my favorite engine but I'd never carb one. I'd carb a vortec first. I hope it works out well for you though.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It would be more work and expense to put a carb on the LT1 than it would be to wire in the LT1 EFI.
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Re: 305 to lt1 help
EDIT
I have a stock FBody lt1 cam if your interested.
