oil pan and motor mounts.
Old Sep 18, 2014 | 09:24 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Hey guys, having a hard time finding a 4th Gen oil pan and I was told that a ctsv pan would work. I just wanted to clarify if it would fit. If so the said yrs of the ctsv?
Also I plan on using the mounts from summit. Part # TRD-4572. Thanks guys. Really itching to get this beast dropped in
Old Sep 18, 2014 | 09:49 AM
Pocket's Avatar
Car: 91 Trans Am
Re: oil pan and motor mounts.
The CTS-V pan hangs lower than Fbody by about an inch. I would avoid it
If you have a tubular K-member any C6 pan will work. The C5 batwing will clear some tubular K-members
There really isnt an inexpensive off-the-shelf pan kit. If you have a dealer hook up, the Fbody stuff at-cost is about $250
The mounts listed are for a standard SBC conversion which is a misnomer. 1" setback plates put the bellhousing flange in the same location as stock so the stock DS can be retained for most common trans choices. Hopefully you will not be using the 700R4
You want something that looks like this:
Old Sep 18, 2014 | 11:16 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Yep those are the mounts from summit. As far as the pan goes I've been trying to get used and have seen the ctsv pan but I'll just wait for the fbody one. As always pocket thanks for the info!
Old Sep 18, 2014 | 01:48 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I am running a new Fbody pan (price matched on summit for $198.50, then the pickup/windage) I price matched superchevyperformance.com's price) And I am running Spohn mounts with 4th gen Poly engine side mounts. Seems to fit well despite all the issues I have read about. The Drop in the pan comes really close to the K-member though.
Jay
http://www.superchevyperformance.com...p/12628771.htm
http://www.spohn.net/shop/1982-1992-...ng-Stands.html
And these but with POLY inserts. I will eventually go solid if the motor moves too much. I got them for dirt cheap though
http://www.spohn.net/shop/1982-1992-...Clamshell.html
Old Sep 18, 2014 | 01:55 PM
Jay_rich's Avatar
Car: 1987 Z28
BTW I used those adapter mounts before and they were garbage in my experience with solid mounts. I had to grind the hell out of the back of the stock clam shells so they would fit flat, then I had to slot the holes since you are moving the mounts away from the block 1/2" so it actually makes the bolt pattern wider.
I ended up assembling the mounts/adapters/K-memeber mounts all to the motor then welded them to the K-memeber.
However lots seem to have success with them. Maybe the ones I got wern't as good. They were somewhat never at the time.
Jay
Jay
Old Sep 19, 2014 | 03:44 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
That's good to know, I think I'm going to try them out since there's more people with success than failure. Atm I plan on focusing on getting it in and playing with it. I think ultimately I will be going with a tubular k member. Who knows hopefully I'll have better luck. But I know who I'm calling when I need help haha
Old Sep 19, 2014 | 04:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I used Spohn mounts with 4th gen clamshells on my first 3rd gen LS swap, and had all sorts of trouble getting them to line up. Solution? Think "big pry bar".
Used the adapter plates (no offset) on the second 3rd gen LS swap, and ended up opening up one clamshell hole to get the bolt to go through.
I used adapter plates (with 1" setback) on the '57 LS swap (which already had 3/4" to the forward side mounts installed), and they lined right up.
So, I'm more inclined to blame the 3rd gens than I am the adapter plates.
Old Sep 19, 2014 | 04:52 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Haha, yea I'm sure it's not just gonna go right in but we will see what happens
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
