Stupid question time: Switching from truck to Fbody accessories
Old Oct 7, 2014 | 07:52 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I have an LQ4 truck engine and am only going to run an alternator + waterpump.
1. Can I switch to an f-body waterpump and the stock balancer for the serpentine belt will still line up?
2. Is there a low mount alt bracket that will clear the steering shaft? Do I need a idler pulley also?
Old Oct 9, 2014 | 10:21 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Stupid question time: Switching from truck to Fbody accessories
A few things:
Truck spacing and Fbody spacing are different. To use a Fbody low mount alt/bracket, you need to space it off the block 3/4". Next, the iron block will NOT have two of the three holes for the bracket. One boss is present, but undrilled, the other is missing completely. It will mount properly with two bolts
Fbody WP makes life easier with the waterneck location more-so than pulley depth. An alternative is to use a 5th gen camaro WP and C6 upper rad hose to keep the truck pulley spacing
To delete PS, simply switch the smooth idler for a ribbed pulley on the Fbody bracket and run a shorter belt. The bracket is so simple a flat plate and two threaded rods will do the same job
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
ZsTransAm
Aug 11, 2015 07:30 PM
