3rd gen k-member and lsx mounts
Old Oct 9, 2014 | 09:45 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Hi, I have a question (obviously - lol)
I have a stock notched k-member and spohn adapter plates. I know how it is positioned on the k-member, but I want to know what bolts everyone is using. Meaning are there stock bolts, or is there something else, grade would help. Since it is a bolt and nut, what torque specs is everyone using? Also, when I get my engine, what torque specs should I use to tighten the mount to the block. Is there anyone that sells a complete bolt kit for the engines? The latter I have not looked into much, but I nevertheless would like a little advise.
Thanks guys.
ps: swap is near... my charcoal canister failed today and I took it on the highway at high speed, felt like the transmission was going to shake loose and come through the floor. I can't wait for the swap!
Old Oct 9, 2014 | 10:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 3rd gen k-member and lsx mounts
Mount bolts arent critical, use whatever is available, originals work fine. Torque values arent critical either, google the industry standard for whatever size/grade bolt you use if worried about it
I use grade 5 3/8" bolts with lock washers torqued as tight as my stubby spark plug ratchet can get them (30ish lb/ft)
Old Oct 9, 2014 | 10:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
All the bolts are M10x1.5 so you can use the same 37 lb-ft torque for everything.
The large thru-bolt in the engine mount is 70 lb-ft.
Reuse the K-member bolts. You might need to get another set to make it four per side.
Old Oct 9, 2014 | 10:19 PM
alex722607's Avatar
well that's a start, thx Pocket .
Old Oct 9, 2014 | 10:23 PM
alex722607's Avatar
lol we posted at the same time!
thanks that's even better
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
NBrehm
Aug 5, 2015 07:57 PM
