Getting the Ls1 fuel gauge to work
Old Jan 30, 2015 | 09:26 AM
SsBenj's Avatar
Car: 1989 Iroc-Z
Transmission: Tick Stage 2 T56
Axle/Gears: 2.77
I'm trying to finish up my Ls1 swap into my thirdgen and I decided to go with the ls1 Camaro gauge cluster and I can't get the fuel gauge to work. I read up something about a resistor but they're all using 4th gen tanks. My question is would I need to change over to a 4th gen tank or can I make the Fuel gauge work with my Thirdgen tank? If there is already a thread on how to do it please post the Link
Thanks,
Ben
Old Jan 30, 2015 | 08:38 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Getting the Ls1 fuel gauge to work
The resistance sweeps are totally different. Since you're in california, how did you pass the car with the stock tank?
Old Jan 30, 2015 | 10:12 PM
SsBenj's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.77
So there's no way I can make it work with the thirdgen tank?
As in pass smog/ inspection? I haven't figured it out yet. There's always someone out here in LA that knows a guy who can get my car to pass.
Old Jan 31, 2015 | 09:50 PM
Pocket's Avatar
Car: 91 Trans Am
Find a sender with a resistance sweep that matches the gauge and stick it in. IMHO, its easier to use a LS1 plastic tank, esp in cali
Look on the bright side: never rust, has the parts you need, fuel bucket is superior during cornering, correct fuel pump already installed, correct sender, removable neck makes tank swaps easy
Old Feb 2, 2015 | 04:43 PM
SsBenj's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.77
Got it, I appreciate the great insights Pocket. I'm going to go with the forthgen tank.
Thanks,
Ben
Old Feb 3, 2015 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"...someone who knows a guy who..." is a pretty shortsighted way to operate. Might get you by for one test cycle, but how about next time when that "guy" has been put out of business?
The 4th gen LS tank is the right way to go. It will have what you need to pass emissions properly.
Old Feb 4, 2015 | 12:51 AM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I went with the 4th gen tank, they can be had so cheaply there is no reason not to. On my firebird I even modded the factory 3rd gen gauge to work with the factory 4th gen sender.
Old Mar 1, 2015 | 01:55 AM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
How did you mod the 3rd gen gauge for the 4th gen tank?
I have a ls1 tank and I want my factory gauge to work
Old Mar 2, 2015 | 09:50 PM
Z28Disaster's Avatar
^^^^^x2
Old Mar 3, 2015 | 03:35 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
This has already been covered, by $750, just click on his name, View public profile, view statistics and then click "all threads started by user" or "all posts by user"
Old Mar 4, 2015 | 05:48 AM
nhra-trans-am's Avatar
I used a sending unit from a grand prix that has the right resistance range for the 3rd gen gauge
Old May 20, 2015 | 09:23 PM
Engine: 5.7 350 TPI
Can something like this bolt on to the ls1 fuel bucket?
Will this work for a thirdgen gauge?
http://www.carid.com/dorman/fuel-level-sensor-mpn-911-008.html?gclid=CJP5ofzi0cUCFQYxaQodqmEAmA
Old May 28, 2015 | 02:49 AM
$750 L98's Avatar
Sorry I haven't been as active here lately, I've been working on a HEMI project along with reviving a 4th gen Camaro that was hit by a drunk. However, using a stock fuel gauge with modified resistors and an unmodified 4th gen fuel tank is still the easiest and cleanest way to swap to a LS fuel system.
I haven't yet modified a 3rd gen Camaro gauge, though I'm sure one day when I come across a good roller, I'll have to give it a go. The Firebird gauge is amazingly easy to modify though, and I imagine the Camaro is very similar.
Link for that mod is here: https://www.thirdgen.org/forums/ltx-...auge-40-a.html
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
armybyrd
Dec 5, 2015 09:22 AM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
