Spohn motor mount help!
Old Feb 1, 2015 | 12:40 PM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I am in the process of seeing how much I need to notch my k member. I installed the mounts loose. I ran the bolt through the clamshell on the passenger side. When I tried to install the bolt on the driverside this is how far off I am. Is this normal? If so, how has someone installed them? Want to make sure I am not doing something wrong. Thanks
Old Feb 1, 2015 | 01:05 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Spohn motor mount help!
I didnt slot mine at all but it was a pita to get them in. When I installed mine on the K member I slid them up as high as possible. When I installed the mounts I used 1/2 bolts which were almost size for size with the poly inserts which made it a huge pain nut i got them with help from a pry bar and a hammer lol.
I did have to notch about 1/2" out of the back of the kmember so the oil pan wouldn't hit
Jay
Old Feb 1, 2015 | 02:49 PM
Engine: 5.7 Liter
This is a bit ridiculous. I am about to order umi mounts. Have people modified there mounts to fit?
Old Feb 2, 2015 | 08:24 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I used the stock mounts on k member and just the setback plates. I also dropped the motor in but I had to use a pry bar and hammer for it to get to the sweet spot.
Old Feb 2, 2015 | 10:34 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I installed everything loose, including the crossmember side, and then tightened all the bolts once the engine was in. No prying necessary. Are you sure you have the proper mount on each side? There are also several holes in the crossmember, are you sure you are in the proper ones? Also the engine side mounts can install down side up I believe?
Old Feb 3, 2015 | 06:09 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I had to shim the passenger side mount about 7/16ths from the block to get the motor to sit level and to get things to line up
I also installed everything loose
FWIW, I've heard using poly mounts make it 3 times harder........ and that appears to be what you are using........
so a hammer and pry bar maybe in your best interest
Old Feb 3, 2015 | 07:36 AM
Engine: 5.7 Liter
I am going to double check everything this weekend. Seems weird that you have to pry a mount that was designed for this application.
Old Feb 3, 2015 | 08:18 AM
Jay_rich's Avatar
Car: 1987 Z28
Spohn seems to be well known for bad fitment on everything they make for our cars. So its not weird to me. What I noticed is spohn basically makes the mount holes WAY bigger than they need to be to compensate. which makes it a pain bc a lot of people dont think when they bolt them down. Being a machinist I notice small things. Spohn drills the mounts 1/2"(0.500"), The K-member is drilled 10mm which is 0.3937". Gives a lot of room for error.
I also didnt have instructions since I bought mine used, but maybe spohn states to slide them up to the outside/top then tighten them down, and maybe they used 12mm bolts (0.4724") Instead of the 1/2 I was supplied with which are size for size with the poly mount through holes. I know when i yank my motor I will have a tough time getting them out. But I already had one pounded in so I just stuck with it. Next time the motor comes out a PA racing K-member and arms will be going in place for sure.
Jay
Old Feb 3, 2015 | 09:41 AM
Engine: 5.7 Liter
Yeah I doubt I will buy anything Spohn again. I am leaning towards UMI mounts right now.
Old Feb 3, 2015 | 06:57 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Do these mounts require the k member to be notched for all applications or only if you're retaining A/C?
Old Feb 3, 2015 | 10:44 PM
Engine: 5.7 Liter
Looks like it will clear my fbody oil pan but I am still going to notch it for my own comfort.
Old Feb 4, 2015 | 12:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are you using on the engine side? Are they from Spohn as well?
I had factory 4th gen engine side mounts and replaced the inserts with poly. They can be put in backwards, messes things up.
Old Feb 4, 2015 | 06:04 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I remember having to fiddle with my Spohn mounts as well but that was 8-9 years ago. The motor still does not sit exactly level side to side.
Old Feb 4, 2015 | 06:31 PM
Engine: 5.7 Liter
/\ that is my exact setup. Maybe I have them backwards. I will check that out tomorrow.
Old Feb 6, 2015 | 08:24 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah check that out... I have stock 4th clam shells with prothane poly mounts, and Spohn stand offs. Everything bolted together great, and I can remove the k-member off the motor, and put it back in without prying or doing anything forceful.
Even if people said a particular conversion mount didnt require notching of the k-member for oil pan, I think I would still notch it if I were to swap another car. Only because you never know what your clearances will be until its all in. And once its all in, its a pain to take it back out. Ide rather just cut, weld, and install and be done.
Justin
Old Feb 6, 2015 | 05:39 PM
Engine: 5.7 Liter
So I ended up having one of the mounts upside down. Everything lines up good now. I will feel better with more oil pan k member clearance so the notching begins.
Old Feb 16, 2015 | 08:02 PM
Pocket's Avatar
Car: 91 Trans Am
This is the proper way to install mounts, rubber, poly and most definitely solid. Spohn is known to have a droopy pass side mount
Old Feb 23, 2015 | 07:12 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
https://www.thirdgen.org/forums/ltx-...ues-spohn.html
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
