LS2 T56 ram power grip HD clutch issue
Old May 11, 2015 | 02:45 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I installed a new RAM Powergrip HD complete with their billet steel flywheel in my LS swapped IROC just before the winter, drove it for a few day, and then the car has been in the garage until now when the snow starts to clear.
The scary thing is that the clutch engagement point is just as the pedal nearly is completely at the top/up position. I get some chatter and then I can move the pedal about half an inch(10-12 mm) or so.
I have gotten the TICK Mastyer cylinder, and the updated GM slave 2001+ in my T56/MN12 LS2 swapped Iroc.
What could be the reason for this? I know that the bore/stroke of the TICK MC is completely different from the stock plastic GM MC, but the car should engage somewhere halfway down/up the pedal stroke, right? The car drives OK, but it feels like as if the clutch is totally worn out.
I did not use a shim behind the slave, I the way I see it that would have made it worse going that direction, OR?
theshackle
Sep 17, 2020 08:26 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
86White_T/A305
Aug 17, 2015 12:16 AM
rsrmoore
Aug 7, 2015 08:44 PM
