Jegs LS Swap Oil Pan - Anyone use this?
Old May 28, 2015 | 03:22 PM
Beaner_88's Avatar
Car: 1987 Camaro
Engine: 2.8L V6
Axle/Gears: 3.42 Non Posi
http://www.jegs.com/i/Chevrolet-Perf...10#moreDetails
Chevy performance Ls swap oilpan with the windage, sump, dip stick, gaskets and pan.... seems really cheap. Could be good or bad.
Anyone running this on their car? Would make me lean more towards 6.0L. All the LS1's I can find right now are $2000 plus with higher milage.
Old May 28, 2015 | 04:51 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: Jegs LS Swap Oil Pan - Anyone use this?
Lots and lots of threads on this. Will not work. Hangs too low and doesn't fit right. Either you'll have to find a cheap used LS1 setup for the pan, or do what I did and just spend the $279 on the complete set up, new.
Edit: https://www.superchevyperformance.co...tCode=12628771
Old May 28, 2015 | 08:57 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
You can always hunt on Craigslist like I did. Still was about 150 for everything
Old May 30, 2015 | 12:38 AM
Beaner_88's Avatar
Car: 1987 Camaro
Engine: 2.8L V6
http://www.superchevyperformance.com/ShoppingCart.asp
That everything that I would need?
Old Jun 1, 2015 | 08:51 AM
R13_Braz's Avatar
Car: 2014 Z28 #80
Shopping cart shows as empty.
Here's what you need:
12628771 LS1 F-Body Oil Pan Camaro Firebird 1 $198.99 $198.99
12551581 Oil Level Indicator (Dipstick) 1 $13.58 $13.58
12551577 Oil Indicator Tube (Dipstick Tube) 1 $8.80 $8.80
12558253 LS Windage Tray1 $18.49 $18.49
12558251 LS1 F-Body Oil Pan Pikcup Tube 1 $35.01 $35.01
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
