LS swap into 87 GTA question
Old Oct 5, 2015 | 04:53 PM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
I'm looking to do an LS swap on my sons GTA. I'd like to keep all the creature comforts like AC.
Don't want to go through the trouble of cutting / notching the OEM k-member for ac compressor clearance. Can some of you guys that have done this give some suggestions on aftermarket k-members to use ?
Old Oct 5, 2015 | 05:06 PM
Fox118's Avatar
Car: 89 Firebird
Engine: None
Re: LS swap into 87 GTA question
There's a company that makes a bracket that allows you to run the stock compressor with an LS without modifying the k-member. (stock to the car)
something like kwikperformance? I dont have it in front of me.. and of course I can't find it :/
otherwise umi makes an ls tubular k-member but for the money.. seems like the bracket is cheaper.
Old Oct 5, 2015 | 05:08 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
http://www.ebay.com/itm/R4-A-C-Reloc...-/161281490614
Pricey but it works
Old Oct 5, 2015 | 08:11 PM
Engine: 5.0 TPI
Thanks for the postings guys !!
Keep the suggestions coming, PLEASE !
Old Oct 6, 2015 | 05:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by RockJay81
That's the truck accessory version. Note they also make Camaro and Corvette accessory versions.
Old Oct 6, 2015 | 05:36 PM
five7kid's Avatar
I believe Kwik Performance only makes Sanden AC compressor brackets.
Old Oct 6, 2015 | 08:54 PM
86gn's Avatar
Car: 92 Vert
Im running a older sphon LSx swap K-member and granted there was a grind here and there to get it to fit how I wanted but im running the LS1 stock ac pump using hawks swap hoses and works great. Its blowing 38 at idle and 32 cruzing down the road and thats in a vert.
Old Oct 7, 2015 | 02:30 PM
Beater79TA's Avatar
Holley also makes bracket systems. As do a number of other companies like Eddie Motorsports. The real question is how much do you want to spend? Some of the complete serpentine kits cost more than a tubular K member.
Old Nov 7, 2015 | 02:05 PM
Pocket's Avatar
Car: 91 Trans Am
The holley bracket is very affordable. Comes in any accessory offset and in R4 or sanden versions
TexasRaider
Feb 11, 2011 01:07 PM
AZZ28
Jan 25, 2008 03:34 AM
Corky
Jun 10, 2007 09:57 PM
smoove2022
Mar 30, 2006 09:23 AM
