Does this piece stay or go? LS1 swap...
Old Feb 24, 2016 | 08:16 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
There isn't a wire for it in my painless harness so I'm assuming it serves no purpose, correct? Can I remove it and plug the intake? Or does it need to stay?
And what is this piece?
For those of you with a 6 speed, did you guys wrap your clutch hydraulic line with a heat wrap? Mine runs right next to the header... Seems like it would get the fluid too hot.
Old Feb 24, 2016 | 08:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Does this piece stay or go? LS1 swap...
Its the Purge solenoid for the charcoal canister. Emissions stuff.
Old Feb 29, 2016 | 10:50 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
I've got mine setup to use it (not using a painless harness), it's called a purge solenoid valve. If you have the charcoal canister setup to be used, it needs to run to this valve, so it's not receiving vacuum all the time. If not, ditch the valve.
Old Mar 1, 2016 | 03:46 PM
WTR388's Avatar
Car: 87 Trans Am
That's why I don't remember it, it got chucked in the trash lol.
My clutch line just goes a "stock" route, kept it as far from the exhaust as possible, no problems.
Old Mar 3, 2016 | 06:33 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Thanks for the help... I yanked it off since I won't be using a charcoal canister
Old Mar 14, 2016 | 03:22 PM
Fireslash's Avatar
Stupid question probably, but if you remove it, do you need to place a cap of some sort where it connect to the intake?
Old Mar 14, 2016 | 09:11 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Yes. Also got a Tick remote bleeder.
1988_f-bird
Mar 7, 2016 08:29 PM
Spaceboy1980
Feb 18, 2016 07:06 PM
apie2546
Feb 8, 2016 02:04 PM
Drone358
Feb 4, 2016 01:22 PM
Gunner242
Jan 30, 2016 10:42 AM
