Wiring harness questions for LSX
Old Jan 28, 2016 | 03:02 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Two quick questions then I can complete my harness.
What do I need to wire in to use the lsx ac, both the clutch and pressure?
Second, what are the common groupings? I didn't label mine before cutting them and this info would help me out tons.
Thanks for any help given!
Old Jan 29, 2016 | 03:30 PM
Car: 1990 Camaro RS
Engine: L31
Re: Wiring harness questions for LSX
So I think I need the pressure switch also from all the reading I have done but I'm not 100% sure.
Old Jan 31, 2016 | 04:30 PM
Car: 1990 Camaro RS
Engine: L31
Ttt
Anyone know the common groupings?
Old Feb 3, 2016 | 05:46 PM
Pocket's Avatar
Car: 91 Trans Am
If running a low mount LSx compressor, then you want it to be completely PCM controlled. 3rd gen AC request signal comes from the connector over the HVAC box (lt blu 18ga). PCM checks pressure via the three wire sensor. If the pressure reads good, then it grounds the AC relay and 12v is sent to the compressor clutch and a feedback wire goes back to the PCM to confirm operation
Commons refer to groupings of wires to do a common function, schematics often label them as splices. These can be a number of things, often grounds, power for each bank of injector/coils, emissions equipment power, low reference sensor groups and genuine splices such as the feedback wire on the AC system
For a normal swap harness you'll need the grounds (obviously), one for each bank of inj/coils, HO2's/trans/AC power, 12v battery PCM/ALDL, AC/IAT low ref, AC clutch 12v/feedback to PCM and FP relay/PCM batt splices
Old Feb 4, 2016 | 01:29 PM
Car: 1990 Camaro RS
Engine: L31
Thank you so much for the reply. If you don't mind clarifying, how are the commons grouped? Like are both banks of the injectors in one group to the ignition, etc?
Thanks Pocket
Old Feb 4, 2016 | 07:05 PM
Pocket's Avatar
Car: 91 Trans Am
You will have an inj1 and inj2 fuse in the block already. In a literal sense, you can have any 4 injectors and a bank of coils together on one. Often its all the evens vs all the odds, but theres no rule to have any particular injector on a particular fuse
Old Feb 9, 2016 | 02:56 PM
Car: 1990 Camaro RS
Engine: L31
Thanks for the info. I've been doing tons of reading.
It looks like the MAF, trans stuff, and O2s are all fused at 20 amps and the injectors and coils are fused at 15 amps. So you suggest 1 injector bank and 1 coil bank per fuse, I'm guessing the trans stuff can all share a fuse but the rest probably need broke up since they are 25% more amps. Is this the right track?
Thanks!
Old Feb 18, 2016 | 07:06 PM
Pocket's Avatar
Car: 91 Trans Am
I keep bank 1 INJ/IGN, bank 2 INJ/IGN, PCM IGN/MAF, FP relay/PCM batt fuse in the external holder, fan relay fuse, AC/HO2s/trans on the same emissions fuse point, C100 A7 for your 90
For carb cars and stand alone harnesses, I split each up because there are more fuse points to choose from and its easier to trouble shoot
rusty vango
Jul 5, 2016 03:09 PM
stenseltizm
Feb 26, 2016 11:30 AM
usmechanix
Carburetors
31
Feb 2, 2016 06:56 AM
Goodolboy0404
Jan 30, 2016 03:23 PM
Gunner242
Jan 30, 2016 10:42 AM
