36" plug wire.....too long?
Old Dec 6, 2017 | 02:33 PM
indebt's Avatar
If I mount the coils under radiator support, that's what my longest will be. Opinions? I know shortest is best, but can't' seem to get them any closer. Anybody did this?
Old Dec 6, 2017 | 07:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 36" plug wire.....too long?
I assume you are referring to an LS swap? How is there enough room under the radiator support for 8 coils?
Old Dec 6, 2017 | 07:47 PM
indebt's Avatar
Yes. Plenty. I think I'll mount them there. I could possibly mount to the block in front of the motor mounts, with a 2 top, 2 bottom approach. I guess I'll run what I have mounted now and see
Old Dec 6, 2017 | 07:51 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Ah I see what you mean now. Length isn't going to hurt you that much. I would be more worried about road debris. These coils can crack pretty easily if impacted by anything.
Old Dec 6, 2017 | 07:55 PM
indebt's Avatar
OK thanks. Just a fair weather driver/track car. Your right, I dropped one not far and it cracked on the plug boot end. Might add some partial cover for them
Old Dec 6, 2017 | 07:57 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Exactly. I dropped one on my workbench and broke off the plug end.
Old Dec 7, 2017 | 09:57 AM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
I like those mounting brackets for the coils. Did you make them or get them from somewhere?
Old Dec 7, 2017 | 10:01 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I do't think you could have chosen a worse place to mount them
Old Dec 7, 2017 | 01:32 PM
indebt's Avatar
They are ICT's. I think $49 on Ebay. I got mine from a guy doing a discount on ICT stuff on LSX swapped third gen FB group.
Old Dec 7, 2017 | 01:35 PM
indebt's Avatar
Because of length?
Old Dec 7, 2017 | 01:43 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I would be concerned with the free wire length from the coils to the motor.
There was a super modded C4 Lingerfelter vette that had coils mounted under the motor somehow. Looked super clean. I would look for other motor centric mounting locations if I was you.
I will be doing an LS3 swap soon on my build and will be looking to hide them as well, so I understand.
Old Dec 7, 2017 | 02:00 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I had one break just removing the spark plug wire.... so now I have 7 extras of the rectangular truck coils if you guys need replacements or spares. Had them for sale for years.... please take them so I can free up some shelf space. LOL!
Just can't bring myself to toss them in the garbage because as soon as I do somebody will say, Oh! I would have bought those!
https://www.thirdgen.org/forums/mid-...ml#post6023217
Old Dec 7, 2017 | 09:38 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
What are you running for front suspension? If coil overs, I have an option for you.
Old Dec 7, 2017 | 10:42 PM
indebt's Avatar
No coilovers. Thanks though.
Old Dec 8, 2017 | 08:56 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Because of length?
Because of location. It's a low spot on the car, in the front. The only "protection" they will have is the air dam, but if you accidentally get too close to a parking stop, or a curb, you're going to have a bad day. I would try to mount them on the side of the block, or even the side of the oil pan, they will be out of the way of everything, short plug wires, and hidden
