LS swap mid-length headers
Old Feb 27, 2018 | 01:18 AM
j99birk's Avatar
Car: 1991 Camaro RS
Engine: LS1 swap in progress
Transmission: 4L60E swap in progress
I was looking at Hedman's mid-length swap headers but after numerous phone calls, no one will tell me if it will work with my Spohn tubular k member and trans mount. Has anyone done this before or know if it will fit?
Old Mar 5, 2018 | 11:42 AM
johnw999's Avatar
Re: LS swap mid-length headers
I think the headers are designed to stay clear of the engine mounts, so I don’t think an aftermarket K member would be a factor. Also, the mid-length headers won’t go past the bellhousing. The y-pipe is the section that passes the cross member. This thread has some good photos of the hedman mid-length headers:
https://www.thirdgen.org/forums/ltx-...-28-6-a-2.html
Old Mar 5, 2018 | 05:55 PM
a383z's Avatar
Why do you want to go with mid length versus long tubes.
Old Mar 29, 2018 | 10:07 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Thanks for the mention, that's my build thread. I was the first on the boards to try the mid-tubes. 6-7 years later they are still going strong.
OP with less in the way, I'm sure they would clear. I see no reason they wouldn't.
Ground clearance. Also, the fractional amount of torque you would give up is a non-issue. My car puts down 422rwhp through the mid-tubes. Unless you want a dyno-queen track car, squeezing every last .01 out of your ET, the mid-tubes are great option for someone with a street driven car.
Old Apr 2, 2018 | 07:52 AM
johnw999's Avatar
The only reason that I have the hedman long tubes is that another member sold me a new pair for a great price. Ground clearance is a PITA, though. I can’t take it to the quick oil change places. They sound great, but I did an LS swap again, I’d go mid-length.
Old Apr 2, 2018 | 02:11 PM
Justin Hertel's Avatar
I just got the Kooks 1 - 7/8" mid lengths and had 0 issues, even though they say they recommend an aftermarket cross member. I can drop them in and take them out without needing to bang them on anything, or lift the motor as well. I went with them for clearance as well. I'm a huge fan of these mid lengths.
ambainb
LSX and LTX Parts
Jul 1, 2016 11:28 AM
91 camaro rs
Jun 27, 2009 01:19 AM
Beachmonkey6
Jul 4, 2006 06:23 PM
HM Murdock
Nov 27, 2003 03:06 AM
