LM7 to 4L60 Flexplate Option Question
I'm building a budget for a potential LS swap.
I've searched and have had several hits regarding the flexplate needed to adapt my freshly built 700R4/4L60 onto a 5.3L from either an 03 or 06 Tahoe (I have both).
Who is using what or other suggestions/opinions?
Car: 1989 TPI Formula, 1984 MCSS
Re: LM7 to 4L60 Flexplate Option Question
Good for you on being able to pull a known running motor.
The 5.3 usually has the dished bolt hub.
The easiest, cheapest solution is the 551165 ICT billet hub adapter. Lots of them on eBay. This one is good quality.
