92 tpi enging shut down
Old Oct 12, 2018 | 11:29 PM
61 chev's Avatar
Want a title? Post!
street rod 92 tpi will shut down when door is opened..orwhen fan controller comes up to 150 deg..has blowen fuses to fan... will a small short be enuf to short out the ground on the ecm.Will start right up again..open the door and quits again .4 dome lights in the car wireing....door switch.. what will trip the ground for the ecm ? Barry Larson 763 753 4340 mn
Old Oct 13, 2018 | 11:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 tpi enging shut down
Does the efi harness run by the door ?
whats missing when the engine dies, fuel pressure, spark , injector pulse ?
Old Oct 13, 2018 | 11:46 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Did you just put this together? What did you do, tie your ECM power into the interior lighting?
Old Oct 17, 2018 | 04:13 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
is this a spam bot? If not I'm going to guess you are missing the ground strap from the body to the engine. The load of the interior lights is pushing your electrical potential on the ECU below its threshold. (or about 1000 other possible ground issues) Does engaging the headlights or power windows also shut it down? If not you may have accidentally used the interior light circuit as your ground, it will ohm to ground because of how incandescent bulbs work.
94ElBanditoDeCa
Feb 27, 2017 10:35 PM
factory89tpi
Sep 29, 2016 05:24 PM
Jayking
Sep 27, 2016 08:55 PM
Lucid
Mar 7, 2009 07:36 AM
Vader
Mar 16, 2002 10:58 AM
