Lt1 swap
Old Oct 26, 2018 | 09:10 AM
89birdLt1's Avatar
Lt1 swap
Hi guys
i have a 89 firebird 305 T5 trans. Have a lt1 out of a 95 camaro with harness cpu etc ....
wondering if anyone has any tips or suggestions to make the swap go smooth
Old Oct 26, 2018 | 12:28 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Lt1 swap
there is ton of great info/write ups on this site,just check out stickies/forums/search feature....
Old Nov 28, 2018 | 09:53 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Lt1 swap
It's been done many times so there is a lot of info here. The engine itself will bolt in with no problem using the existing motor mounts. Wiring will always be the most important part but there is a lot of stuff online to help merge the engine harness with the body harness. You'll need to get the LT1 specific flywheel and clutch kit but everything else will work, assuming the T5 is staying the car. The LT1 heads use a D-port exhaust shape so LT specific manifolds would be best. I ran generic SBC summit headers on my LT1 for years and never had a problem, but the 3rd gen camaros are a bit tighter than the 2nd gen so full length headers are probably not an option. You may also want to look at running an aftermarket radiator or finding a 4th gen radiator. Many people have ran the stock 3rd gen radiator but the ports are not quite where they need to be so it could cause overheating since the suction hose is in a different spot on the LT1 water pump than on a standard SBC pump.
Old Nov 29, 2018 | 04:55 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Re: Lt1 swap
I'm in the same spot as you OP. From everything I've read, it's a drop in operation. Wiring is what throws some people off. Pocket has a how to for the harness that is pretty good. My understanding is you don't have to take the harness down completely but just depin what you're not using. Obviously this will limit where you can put the PCM. Having the underhood fuse box from the donor car will save some headache as well. I hope to be putting money in over the next few weeks. Gotta clean it up, reseal, throwing in a Comp cam 503 then throw it in. Not gonna worry
about AC since that's another battle.
Old Nov 29, 2018 | 06:07 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Lt1 swap
For the most part the stock LT1 harness is stand-alone'ish.
On my harness I basically fed it power, ground, starter, and fuel pump relay. Everything else was mostly gauges for the C100.
Long Tube headers fit, just need Thirdgen SBC headers. I have the Hooker 2210LT's on mine and the process for them on an LT1 is the same as any SBC in a Thirdgen.
Old Nov 30, 2018 | 08:14 AM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
Re: Lt1 swap
Agreed...I wish I had left mine stand alone,it makes the swap easier.
Third gen sbc headers will work fine.
Your 305 flywheel and clutch will work as long as you are keeping the T5,the only time you need the Lt1 specific flywheel and clutch is if you are using an Lt1 style T56 trans.
blackgold84
Feb 3, 2011 05:43 PM
chevyowner02
Dec 4, 2006 04:05 PM
Thirim
Mar 5, 2004 06:02 PM
Dean-B4C6SPD
Jul 14, 2003 12:04 AM
David Petersen
Feb 24, 2003 09:51 AM
