Anyone else have problems with shifter cable?
Old Nov 7, 2018 | 06:20 PM
Billgluckman's Avatar
2001 truck engine/trans, including the factory 2001 4l60e shift lever.
88 camaro shifter, replacement 88 camaro shift cable.
The problem is when I push the shifter to park the trans shift lever doesn’t actually travel all the way to the park position. It also won’t travel all the way back into 1st if I pull the shifter it all the way back.
One thing I’m curious about is why there are two different length shifters offered for a v8 88? I’m wondering if I’ve got the wrong shift cable
Old Nov 7, 2018 | 09:36 PM
skinny z's Avatar
Re: Anyone else have problems with shifter cable?
I don't have your application exactly, mine is an aftermarket shifter and cable with a 4L60. Unless I really work the adjustments on the cable ends, I'll either find park or 1st hard to engage. I don't recall, does the factory cable have a threaded end and clevis (at the trans) that can be adjusted? It seems to me that my shifter has some adjustment at the shifter too but I could be wrong.
Old Nov 7, 2018 | 10:11 PM
There’s no adjustment on my cable. I’ve seen that the 4th gen cable is adjustable but I’m not sure if it will work.
Old Nov 7, 2018 | 10:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Doesnt the 3rd gen shift lever use an elongated hole that allows the cable to move back/forth.Dont think the later levers are that way.Maybe try the 3rd gen piece.
Also i think the later levers are longer than 3rd gens ones.This changes the travel range of the cable.Detents on 3rd gen shifter are probably spaced differently than truck shifter.
Old Nov 8, 2018 | 05:40 AM
i don’t have the third gen piece. This is what I assumed the problem was, a travel issue
Old Nov 8, 2018 | 10:59 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have read the replacement cables are not right, and someone I knew replaced one and it wouldn't work. He wound up finding a good used one and it was fine. There is a thread on here about a place that makes "custom" replacement cables that are very well made. A little more expensive, but probably worth it in the long run
Old Nov 9, 2018 | 05:42 PM
This shift lever is the answer. If anyone ever has this issue I pulled It off an 85 camaro with 6cyl. It allows an adjustment and fixed my problem.
project89
Oct 23, 2012 03:49 AM
1986CamaroSC
Sep 12, 2003 06:56 AM
84maroman
Theoretical and Street Racing
Aug 20, 2003 12:40 AM
Black88GTA
Aftermarket Product Review
Aug 22, 2002 10:01 AM
84FTA
Carburetors
Mar 3, 2001 07:29 PM
