LC9 video
Old Dec 1, 2018 | 03:44 PM
johnw999's Avatar
LC9 video
Old Dec 5, 2018 | 11:30 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: LC9 video
Congrats on the swap,looks clean. now add a turbo to it and fly!
Old Dec 5, 2018 | 11:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LC9 video
So how many smiles per mile you gettin' now with the LS compared to the old 305? That's the real measure of success!
Old Dec 5, 2018 | 11:59 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: LC9 video
Hes probably still out driving it because its so much more fuel efficient vs the lg4 laughing his way past gas stations lol
Old Dec 6, 2018 | 07:39 AM
johnw999's Avatar
Re: LC9 video
Old Jan 5, 2021 | 10:03 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
Re: LC9 video
do your stock gauges work still?
Old Jan 5, 2021 | 10:43 PM
johnw999's Avatar
Re: LC9 video
Old Jan 5, 2021 | 11:11 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: LC9 video
yea thats what im looking for when i do a swap, I've never liked the look of after market gauges surrounding the dead stock ones.
Old Jan 6, 2021 | 07:32 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: LC9 video
Originally Posted by johnw999
The VVT and DoD were the first to go when I got the engine. Maybe dyno’s should include hp, tq, and mpg!
I’d love a turbo, but I don’t have enough time to mess with exhaust routing, relocating the battery, etc. I have long tube headers... maybe a rear turbo?
PS lots of smiles.
I can see why people get rid of the DoD. But VVT can be useful even in a performance situation. Can widen the torque band significantly. Not sure why people have such hate for it.
Old Jan 14, 2021 | 10:17 AM
slowbluw91's Avatar
Car: 91 Firebird
Engine: LY6
Transmission: TR6060
Axle/Gears: 4th Gen w/3.73's
Re: LC9 video
Don't know if it is hate, but it has to be removed when doing anything other than a stock drop in motor and ecm,harness,etc. I ran into this when building my Gen 4 6.0L, (cant remember if there were any performance VVT Cams?), but the Holley Terminator i am using would not control the VVT. so i converted it to the 3 bolt style cam. I agree with the benefits of it absolutely, just that the aftermarket has not caught up to optimizing the application for certain applications.
OP: Congrats on the swap! what intake is that, dont think i've seen it before?
Old Jan 14, 2021 | 06:23 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: LC9 video
One thing, is that you can't use VVT in a manual transmission car.
I don't know exactly what the problem is, but you can't get VVT/ AFM unless it's automatic.
I'd assume it needs some kind of feedback from the transmission for load calculation purposes, but I might be wrong.
Old Jan 14, 2021 | 10:14 PM
vorteciroc's Avatar
Top Answer: 1
Re: LC9 video
I did not get to work on, or over see the TR6060 + VVT or DOD/ AFM testing that was being done...
Also the BS reason that GM stated the TR6060 vehicle would not have VVT or DOD/ AFM is because a lighter vehicle does not need the VVT to accelerate the vehicle; nor the DOD/ AFM for fuel savings (Gas guzzler tax).
From the data that I was able to read on this... It appeared that the combination of these parts made for frequent valve to piston contact, broken lifters and bent push-rods on a high-revving decel in gear.
Old Jan 17, 2021 | 02:53 PM
Engine: TBI 305
Re: LC9 video
Thanks for your insider info, vorteciroc! Eye-opening, as usual! Whenever I see that you've posted something, I always read it, even if the subject isn't something I was interested in.
Oof, can't have that when I swap my 'Bird; I downshift for engine braking a lot...
Old Jan 17, 2021 | 04:51 PM
johnw999's Avatar
Re: LC9 video
Old Jan 17, 2021 | 05:01 PM
johnw999's Avatar
Re: LC9 video
Old Jan 18, 2021 | 12:15 AM
vorteciroc's Avatar
Top Answer: 1
Re: LC9 video
Since these engine are of the Over-Head Valve design with 16 valves and only one camshaft...
The current engine arrangement only allows for Advancing and Retarding of the "installed position" relative to the Lobe Separation Angle (Camshaft Phasing).
This works nicely with a smaller camshaft in comparison to what most people here would swap in their engine.
There is simply not enough piston to valve clearance with a larger "performance" camshaft, to use the VVT system... damage will ensue!
Yes I know there are products that restrict the range of motion for the camshaft phaser... however, camshaft profile will still need to be more on the conservative side.
This almost makes me wants to install a camshaft 40 degrees advanced in to some LS engine (No VVT) with a good .649"/ .619" and 239/ 254 @0.050" 114+3...
And then just laugh as I turn the crankshaft over and over... clank, chunk, snap, drop, thud.
Demon355
Members Camaros
18
Oct 3, 2007 03:15 AM
JesasaurusRex
Northern California
Jul 15, 2006 10:41 PM
NEEDforSPEED
Sep 21, 2005 01:04 AM
CustomX
Jan 27, 2003 02:27 PM
jocww
Theoretical and Street Racing
Nov 27, 2002 09:07 PM
