The LSX Swap Build Thread
Old Nov 17, 2020 | 06:58 PM
  #251
Gibby10's Avatar
Car: 86 Iroc
Engine: 355
Axle/Gears: 3:42
Re: The LSX Swap Build Thread
very clean car!
Old Nov 18, 2020 | 07:05 PM
  #252
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally Posted by BADMAN
Need more forward movement of the engine. Pan is butted up against k member. Going to take a break and reavaluate Monday.
Forward or rearward? If the pan is hitting the k member you are going to struggle like I did. I eventually was able to get enough clearance by constantly adjusting the kmember bolts, engine mounts (solid UMI). If I had to do it all over id start with the holley oil pan.
soloc4
Fabrication
90
Oct 21, 2020 10:43 PM
85projectZ28
Jan 3, 2019 04:31 AM
Linson
Dec 13, 2016 03:13 PM
BADNBLK
Oct 1, 2013 07:19 PM
