Eliminate third gen filter
Old Nov 22, 2021 | 01:17 AM
Ryan Mcguire's Avatar
Car: 85 TA
Engine: 5.3 8708 cam 241 heads
Transmission: t56
Axle/Gears: QP Ford 9" 3.73 worm drive
Hey guys,
Finished up my ls swap this past weekend and it looks like I'm getting starved for fuel around 4000rpm. I'm going to redo the whole fuel system (new pump, injectors, fitting etc.). While I was under the car I saw the old 3rd gen in line fuel filter. Since I'm using the C5 filter/regulator can I eliminate the third gen filter? If so, what fitting and things are needed?
Old Nov 22, 2021 | 08:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Eliminate third gen filter
The C5 regulator has a filter and pressure regulator built all into one which eliminates the stock filter. Make sure you don't have a regulator at the fuel rails. You'll need the quick connect adapters to attach to stock fuel lines. Earls, and many others sell them. What fuel pump are you using now?
Old Nov 22, 2021 | 12:06 PM
Car: 85 TA
Transmission: t56
I'm ordering a racetronix kit for the fourth gen tank FG0154-340
513camarors91
Mar 4, 2012 09:12 AM
DizzTransAm
Carburetors
Aug 18, 2011 02:49 AM
CamaroRS91x
Sep 19, 2004 06:12 PM
icebird_1981
Oct 19, 2003 09:02 PM
pjd1959
Carburetors
Jun 22, 2003 10:21 AM
