Does notching the K-Member for LSX A/C ruin it for SBC?
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Just a quick question before I cut into my K - Member again. If I cut the notch for the A/C clearance , does it take out the bolt holes for the Small block motor mounts, or will they still fit fine if I choose to go back to SBC at a later date?
Also, does anyone have the specific part number for the A/C compressor you use in the states, I'm trying to see if this notch/AC setup will work for a right hand drive car in Australia?
I have a relocation bracket on my LS1 for A/C, alternator, and power steering due to clearances, but I'm looking at twin turbo'ing a LQ4 motor I just bough and need to move everything back out of the way.
Thanks guys.
Thanks guys.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Does notching the K-Member for LSX A/C ruin it for SBC?
It does not ruin the k-member. The AC relief mod doesn't alter OEM mounting points.
Any idea how important the little triangle brackets are to rigidity?
I was thinking of removing them and either strengthening them to counter removing some of the web so my alternator clears on the other side.
87irocjohn
Feb 23, 2015 07:11 AM
3.1EyeCandy
May 12, 2010 09:16 PM
