LS1 Oil Sender
Old Jun 30, 2025 | 07:40 AM
upstateRich's Avatar
Car: 1989 Firebird
Engine: 2001 5.7 LS1
LS1 Oil Sender
Looking to see what LS1 users are using for the oil sender at the back of the engine to work with the stock oil pressure gauge
Thanks Rich
Old Jun 30, 2025 | 11:46 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: LS1 Oil Sender
2001 silverado 1 wire oil pressure sensor with the correct pigtail works just fine.
Old Jun 30, 2025 | 08:35 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: LS1 Oil Sender
I used an adapter fitting to use the factory Third Gen sending unit.
Old Jun 30, 2025 | 10:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS1 Oil Sender
Rich, I think you began with a 2.8L V6? You'll get best results with your stock V6 oil pressure sender. Post #1932 will give you an idea what to expect if you try to use LS1 sender, https://www.thirdgen.org/forums/ltx-...ml#post6543207
Old Jul 1, 2025 | 09:03 AM
Car: 1989 Firebird
Re: LS1 Oil Sender
Thanks, yes its a V6 Gauge I am going to do some more reading and see if I can make the V6 sender work
utfan01ss
Mar 17, 2016 02:47 PM
nhedrick007
Mar 13, 2015 01:15 PM
Dreambird
Mar 13, 2015 01:03 PM
bad67ss
Jan 29, 2010 06:23 PM
Really-Slow-RS
Mar 10, 2004 11:14 PM
