3rd gen oil sender in ls1
Old Apr 19, 2013 | 05:26 PM
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
what size npt thread tap do I need to install the stock 1992 third gen oil pressure sender into the ls1 oil pan block off above the oil filter?
Old Apr 19, 2013 | 05:53 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 3rd gen oil sender in ls1
The stock sending unit on the back of the block at the top works with the 3rd gen guage.
Just sayen
Old Apr 19, 2013 | 06:06 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Just sayen
Which wire my engine is a lq4 engine and computer the oil sender on it has 3 wires i tried splicing into 2 of them and my gauge pegged out with both when i turned the key on?
Old Apr 19, 2013 | 06:18 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Not sure about the 3 wire lq sending unit. Most others ( I as well) just use the 99-02 truck or ls1 oil pressure sender, and the thirdgen oil pressure sender plugs right in and works as is.
Old Apr 19, 2013 | 06:35 PM
Dreambird's Avatar
Engine: 6.0l LQ4
I have it wired to the computer as it shows in the schematic does the computer not need the signal? If i switch senders it will be a single wire then correct?
Old Apr 19, 2013 | 06:46 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
PCM doesn't need to see oil pressure, atleast any of the ones I have done, don't. A single wire plug and sender is all you need, that will feed your guage directly through the c100 firewall connector
Old Apr 19, 2013 | 06:52 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Thanks!
Old Apr 20, 2013 | 07:41 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I used the stock 98 oil sender. Two wires, one to ground and the other to c100. Works great!
Old Mar 9, 2015 | 08:26 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
V6 or v8 sender?
Old Mar 10, 2015 | 12:12 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
When I ordered the 98 ls1 oil pressure sensor it was for a v8 and it was a 2 prong.
Old Mar 10, 2015 | 07:25 PM
Engine: 5.7 350 TPI
How did you hook it up to the gauge? Did it work?
One prong to ground and the other to the gauge?
Old Mar 10, 2015 | 07:39 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
I have not hooked it up yet becuase i am still in the process of the swap, but i ordered the pigtail for the 2 prong connector from eficonnection. I am going to connect it to my 3rd gen gauge and ground it. Ill post up the part number for the pigtail later, I dont have it with me at this second.
Old Mar 10, 2015 | 07:42 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
https://www.eficonnection.com/eficon...px?ItemId=1421
Part #:100-00815
Here you go, hope that helps some.
Old Mar 10, 2015 | 10:32 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Quoted from "Pocket"
Take a broken ls1 oil sender and drill/tap the alum base to 1/8npt
Alternately, find a m12 to 1/8npt adapter
Old Mar 11, 2015 | 10:26 PM
Engine: 5.7 350 TPI
I did as pocket said and I'm pretty happy!
Brock the ls1 sender tap it with a 1/8 npt tap and screwed it in worked perfect
Old Mar 13, 2015 | 11:20 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
X2
Old Mar 13, 2015 | 01:03 PM
Pocket's Avatar
Car: 91 Trans Am
Thats the 98 oil sender. Not sure why the PN keeps floating around, but it does. Works the same as later LSx senders. 99-02 Fbodys and 99-05ish trucks used 1 wire senders
98 senders use a 4wd vacuum sw connector from a S10. Top middle pin (A) is gauge, bottom grd. All single wire connectors use pin A for gauge. late 3rd gens use a similar connector with 3 wires. The ORN and GRY or TAN/WHT wires were a FP relay bypass and not used for the conversion
Later LSx and corvettes used sensors which are not compatible with 3rd gen gauges. Those are visually much shorter and used a connector similar to the TPS
NBrehm
Aug 25, 2015 11:49 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
reiderz iroc
Aug 13, 2015 04:57 PM
