Havin fun this winter...
Old Feb 14, 2008 | 01:39 PM
  #151
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Re: Havin fun this winter...
A die grinder is not like a dremel, a dremel is half the size and only electric and will die before you could port one head. A die grinder is a air or electric tool but the air die grinder is very cheap and much better becuase you can control the rpm. I just found an air die grinder for $35 at princess auto. But i would recomend using a dremel for the tbi becuase it's easy to handle and you wont destroy the tb. Paint your blocks and heads black then you can get like yellow accented valve covers and stuff i think that would look better then an all yellow engine, you can get air filters in yellow nowadays and even spark plug wires! :IMO:
Old Feb 14, 2008 | 08:08 PM
  #152
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Yeah.. I used the dremel to great effect on the TBI on low... If they are that cheap then I might pick one up..
Haha, We will see, we will see.
Old Feb 14, 2008 | 08:55 PM
  #153
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Originally Posted by flrtin1
Keep working the goal, you will get there....as far as the price dropping, I wouldn't hold your breath. I for one would rather spend the money and have a 1st gen then spend as much or more to have a 5th gen
these are pictures of my dreams.
grngryoutmyway
Oct 18, 2016 05:48 PM
no green
Mar 3, 2016 05:19 PM
Quzyle
Oct 15, 2015 03:35 PM
92projectcamaro
Sep 29, 2015 07:07 PM
