Headlight Conversions/Upgrades
Old Dec 31, 2007 | 09:19 PM
RS305's Avatar
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
i need help deciding on what headlights i should put on my car. i really like the celebrity single headlight conversion, but i would also like to have projectors. if anyone has any suggestions or interesting finds, please let me know.
Old Jan 17, 2008 | 10:12 PM
Stockcarfan24's Avatar
Car: 1988 Iroc
Engine: 357
Re: Headlight Conversions/Upgrades
I did the celebrity conversion on my 88 Iroc and am very happy with it. Pretty easy to do and have gotten alot of good comments at shows and stuff.
Old Jan 17, 2008 | 11:19 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Post a picture please!
Old Jan 19, 2008 | 11:51 AM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Go with a C/K pickup truck housing. Some models on ebay have the projector look. Different color housings too. A member called "Flynlow***" had them on his car. Looked pretty good even tho the car was teal!
Here, I searched 2 mins for you and found this. Its just an example of what Im talking about.
http://imagehost.vendio.com/bin/view...&vsid=87&vgp=0
Old Jan 27, 2008 | 08:45 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
what I did , I bought 4 hella H4 housings
then I rewired all the lights so that the 2 outer lights are my lowbeams.
then I have 4 highbeams.
and for on the highway I used my foglight switch to switch on the inner lights as 2 extra lowbeams ( don't have any foglights anyway ).
his way I can drive at night with all 4 headlights on without blinding oncoming traffic with my highbeams.
even sweeter, you can convert the H4 bulps later on to Bi-xenon lights. this way you have 4 xenon lights.
people will think its noon when you drive by at night.
if you buy the hela housings with park light in it, you can put in every socket a white LED light. an put them straight on the battery.
if you turn your car off your 4 headlighs will have this white glow in them and you can keep them running for atleast a week withouth having a low battery.
Old Apr 15, 2009 | 11:20 PM
rs camaro92's Avatar
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
I have a set of projector lights i bought off of ebay. there fake. They suck and give no lighting. I'm switching back to the crystal lenses. I have HID kit on order so That should take care of the problem.
Old Apr 15, 2009 | 11:33 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Old Apr 16, 2009 | 05:59 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
ok, let me put some pictures with it.
1) I bought some hella h4 housings.
http://store.summitracing.com/partde...5&autoview=sku
2) I bought 4 H4 lights
an h4 light is a highbeam + lowbeam in 1 lamp.
3) I bought 4 relays
4) I bought some 2,5 mm wires in diffirent colors.
5) I bought some H4 connectors
6) I wired it so that instead of my foglights ( wich I dont have ) an extra set of lowbeams comes on. ( the 2 inner lights on the car )
bigger pictue can be found here
https://www.thirdgen.org/forums/memb...s-belgium.html
or here
https://www.thirdgen.org/forums/atta...ric-lights.jpg
7) I looked at the result. ( 2 lowbeams for normal nightdriving )
4) lowbeams for those really dark nights on the highway.
both headlights or lowbeam + highbeam ( sometimes even a parklight in them ) so I also have 4 highbeams.
Attached Thumbnails Headlight Conversions/Upgrades-finish1.jpg   Headlight Conversions/Upgrades-finish2.jpg
Old Dec 20, 2009 | 01:18 PM
Engine: 3.1L V6
Axle/Gears: stock
Heres what mine look like now. i also changed out the blinker assembly.
Old Dec 21, 2009 | 09:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Valeo projector with D1S 4300k HID lamps (xenarcs).
Old Feb 15, 2010 | 09:50 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
sunscribed.
Tony.
Old Feb 15, 2010 | 10:30 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
What i did was not only convert to h4s but I also converted to both sets of headlights to dual high low beam headlights. That way all 4 headlights are operating all the time high beams and lows. It works great i think especially because now you can aim each set of headlights to offer a wider pattern or have one set lite further down the road while the other pair of headlights illuminates immediately in front of you. Plus i never really like the look of the low beams having only 2 of the 4 lights on. Also for those of you who want a more traditional look like I did year one offers nice H4 conversion housings that look like regular old sealed beam headlights for the factory appearance. Also did i mention this was also a pretty cheap way comparatively to improve the lighting? If i recall the whole swap (relays, conversion housings through year one, wiring, ect) cost ~$70 plus the cost of the H4 bulbs themselves depending on which ones you want.
Old Feb 16, 2010 | 10:55 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
just like I said.
only diffirence is that my inner lowbeams/outer highbeams
are connected to a second switch on my dash to put them on or off whenever I want. this way I dont stress my alternator that much.
rear window defogger + 4 lights + radio + heater + subs can be a little it over the top for the stock alternator
Old Feb 16, 2010 | 09:55 PM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
You can go the expensive route if you want but this way you get Bi-Xenon true projector lights like in my sig.
http://www.cardomain.com/ride/3031799
Old Feb 16, 2010 | 10:31 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
hey that looks awesome where did you get that set up by chance??
Old Feb 22, 2010 | 02:42 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
probably egay.. oh my bad, ebay!
Old Apr 18, 2011 | 02:00 AM
smartin44's Avatar
Those projector headlights aren't legal for street, are they? Where did you find them?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
