Keeping it stock
Old Jul 29, 2008 | 10:47 PM
bonddav's Avatar
Keeping it stock
I have a 91 camaro rs sould i tri to keep it stock or upgrade is what would be worth more down the road i was thinking off butting larger wheels on and up grading engine what does every one the what would be worth more 20 years from now
Old Jul 30, 2008 | 01:26 AM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
Re: Keeping it stock
I think keeping it stock will keep value in the long run. Checking your numbers will help your decision. If the block, tranny, and frame are #s matching then keep it stock. Research older gm cars. See what's getting more green.
Old Jul 30, 2008 | 07:53 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
hey man i am the same way toward my 86 iroc. I am gonna keep it pretty much stock and just do some minor upgrades. But i am keeping this car. I have wanted it for ever so when i finally got it i knew that i wouldn't get rid of it lol Just do what seems right to you. I think a few upgrades wont hurt nothing either.
Old Jul 30, 2008 | 09:01 PM
bonddav's Avatar
what would minor upgades be going to biger wheels i was thinking of going to a biger engine because i have 94000 miles on. I had it since new.
Old Jul 30, 2008 | 09:05 PM
19CAMARO85's Avatar
well minor upgrades like bolt ons on the engine and body mods. I am putting a posi and mabye a few small upgrades. Then some look mods. If you swap engines id look into like an LS1
Old Aug 1, 2008 | 09:11 AM
NobleHdwe's Avatar
Since you have an RS I would do mods to it. It will be many years before these cars are bringing top money. If you do tasteful mods, and nothing to hack it up it will not change value much. Look at some of the first and early second gen camaros that have mods to them. They are bringing pretty hefty $$ with LS-1's, aftermarket wheels, and improvements on the stock setups of these cars. Of course there are 100% original ones out there, but if you don't have as much fun with it between now and then trying to keep it stock then what was it really worth. Just my
Old Aug 1, 2008 | 10:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I started down the stock road once upon a time, and I still enjoy the stock look, but.... Check my Car Details to see how originality was sidetracked.
If you keep the stock parts, you can always go back.
JamesC
Old Aug 1, 2008 | 10:51 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
I wouldn't do anything to the wheels or engine yet. I would first go over the car thoroughly. Check out your bushings, brakes, steering equipment(idler arm, pitman arm, center link) make sure your tires and struts/shocks are good. A good set of sub frame connectors will help your ride quality and body flex. I just feel the basic stuff should be checked before you go into performance mods.
Old Aug 1, 2008 | 10:57 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what drive train is currently in it? If you look at classic muscle cars the ones that are worth money are the high performance version with the best engine available etc. If you have a v6 or a tbi most likely it will never be a real valuable car (think along the lines of a camaro with a straight 6, they get bought faily cheap than the drivetrain is pulled and replaced with a v8 and they turn it into a clone car).
Old Aug 1, 2008 | 11:23 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Dude, mod the hell out of it if you want something fun to drive. It's a 91 RS? Dime a dozen. Don't worry about value ... worry about having fun with your car. I modded my 1-of-663 '92 T/A vert to the max, and many others have done the same. I was a purist when I first got my car and wanted to keep it bone stock based on rarity, but I soon got the mod bug when I decided that I wanted to go faster, have a better ride, etc. And, as said, modded cars if done correctly will hold the same (sometimes more) value than high-production stock cars. If you had a 1LE, Firehawk, Turbo T/A, 350 Formula Vert ... something along those lines ... then it might be wise to hold off. But with your car, start dropping the cash and turning the wrenches. You'll thank me later.
Old Aug 1, 2008 | 03:27 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
If you want a collectors car that will be worth more down the road, then keep it stock.
If you want a cool experience and have fun, then modify it.
Some mods will bring more value in the short term, but lose value in the long term.
Like swapping out a 305 for a 350.
If you want to have the best of both worlds.
Modify it, but keep the original parts so that you can put them back in some day, if you feel like it.
Old Aug 1, 2008 | 09:54 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I would modify it. The RS was pretty common. YOu should do what makes you happy rather than think of the value of the car in 10 or 20 years from now.
I would also keep any parts you take off the car.
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
stalkier
Aug 7, 2015 04:49 AM
