Decided to go for the blacked out theme...started with some light tinting.
Car: 1991 Z28
Engine: SBC
So i decided the first step (not to mention the cheapest) was to use alittle night shade by VHT. My tailights were in good shape, however they had some DA sander scratches in them from the guy who owned it before me. So i started by pulling both tail lights and sanding them with 1500 grit to get good adhesion and to get rid of some of the scratches...worked great. I blasted em and let them sit overnight. They came out good however they were quite dark..at night it wasnt bad but during the day the brake lights didnt show too well. So i then decided to polish them so they still had a tint but were shiny. Here's what i ended up with..
What i started with..
http://cardomain.com/member_pages/sh...jpg?394912-263
After nightshading..
http://cardomain.com/member_pages/sh...jpg?350013-263
http://cardomain.com/member_pages/sh...jpg?080113-263
After polishing..
http://cardomain.com/member_pages/sh...jpg?300213-263
After polishing..
Car: 86 Trans Am
Axle/Gears: 2:77
Re: Decided to go for the blacked out theme...started with some light tinting.
looks good man. i used vht also. did you put a clear coat on top?
here's a pic of mine:
Car: 1991 Z28
Engine: SBC
nope no clear, just wet sanded with 2000 grit. I wish it had come out alittle more...ugh...even? I guess you'd call it. But I am happy with the results regardless..
Your tails look awesome!
Car: 1985 Sport Coupe
Axle/Gears: 3.08
so glad you polished them. before they just looked like faded plastic. i'll keep that in mind if i end up tinting my tails.
looks good
looks good
Car: 1991 Z28
Engine: SBC
yea im glad a polished them...the camera made them look real faded. In person they didnt look so bad..it was pretty stealth, but yea im glad i polished them too.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What did you use to polish them? I did the same thing abou 5-6 monthes ago. I ended up with this after using some car polish...Yours look alot better....
The Reflection makes them look alot more glossy, but they still are kinda dull.
IMG_2486.jpg?t=1221863595
Car: 1991 Z28
Engine: SBC
Take 2000 grit and wet sand them until everything is dull (no tiny shiny dots) then i used, on a wheel, 3M foam polishing glaze for dark colors, tall black bottle...youll find it at a professional paint shop or NAPA.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How much does it usually cost?
Car: 1991 Z28
Engine: SBC
somewhere around 20-25$...its a pretty big bottle
Car: 86 Trans Am
Axle/Gears: 2:77
yea, the main thing is the sanding. i wet sanded it down with 600 grit sand paper. then sprayed on 6 light coats of vht nite shade and made sure there were no runs. waited 15 minutes in between coats. then wet sanded with 1000,1500, 2000. then i took turtle's polishing compund to remove light scratches. spray on 2 clear coats to make it look shiney and to protect it. i think thats about all i did. it seems like every who uses this stuff has a different method of doing it.
LT1Formula
Nov 16, 2015 01:13 PM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
