1985 Camaro Restoration
Old Jan 1, 2010 | 03:30 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I want people to check out my work I am doing on my Camaro. I frequently update my page and have lots of pictures and a story for each one.
it is on car domain. here is the link
http://www.cardomain.com/ride/3382110
Thanks. Please leave your thoughts on my work and my car on here or on car domain. I want to know what you think
Old Jan 1, 2010 | 12:05 PM
vette gator's Avatar
Car: 85 Z28
Re: 1985 Camaro Restoration
Wow! You have really taken on a project and seen it through. Congratulations! It's really nice that someone sees these cars as valuable enough to put so much work into bringing one back. A really impressive piece of work and very well documented.
Old Jan 1, 2010 | 03:53 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks a lot, I really appreciate the compliment.
I am in the process of getting new parts to pass the safety test. So new updates will be up hopefully tomorrow
Old Jan 2, 2010 | 08:48 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
bump
Old Jan 3, 2010 | 03:15 AM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
WOW that frame was gone! Iv seen a floor worse (in a 89 rs i had) but never that much rot on the frame. Way to fix it up and keep it on it rode, I would of set it to the crusher.
Old Jan 3, 2010 | 03:34 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
thanks man, it wasnt too hard to fix. Not as hard as it seems. And this was my first time actully working on a car or anything like that so it turned out pretty good.
Old Jan 3, 2010 | 09:55 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
b u m pp
Old Jan 6, 2010 | 11:08 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
There is some pretty good work done here. It could help a lot of people out because its a common problem with these Camaro's and probably every other car. I'm 18 with little to no experiance and a tight budget and I pulled this off and it turned out well. So check it out (link in my sig).
The main work done was changing the sub frame floor support then making and welding in the drivers side floor pan and fixing the transmission crossmember and mount. Plus lots of other frame rail patching. Also changing the distributer and coil.
Old Jan 7, 2010 | 09:55 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Wait until you restore the interior.
Took me over 18 months just to find/source all the parts.
Many interior parts are discontinued from GM and no aftermarket companies have picked up the slack.
Old Jan 7, 2010 | 10:02 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
hmm. Do you know if fourth gen seat will directly bolt in??
And what parts did you have problems finding??
Old Jan 7, 2010 | 10:44 AM
Car: 89 IROC
4th gen seats are a direct bolt in.
It's probably easier to go to Hawks, MDM, Year One and Classic Ind and see what is available than to list what is not.
More parts are discon than are available.
My interior has cost me almost $3,000 so far. I have repalced over 90% of the interior with NOS....got a bit carried away.
Most costly item was a NOS dashpad ($ 250).
Rarest part was NOS kick panels and spare tire cover panel.
I've only seen NOS kick panels twice on ebay. Last set sold for over $100 US.
Also, I've only ever seen one NOS tire panel (in the original box)...it's sitting in my car...
Bear in mind my interior is black which is very desirable (and expensive).
My build link.
https://www.thirdgen.org/forums/show...7&goto=newpost
Old Jan 7, 2010 | 10:48 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Do you have a car domain page or anything like that where I can check out your interior??
Old Jan 7, 2010 | 10:55 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Wow that is some good work. Give yourself some credit. I think that was a difficult job. I just did driver floor and my frame was rust free. Just the floor had rust. I thought I had it bad. You did yours in half the time it is taking me. I still have some welding and sealing to do before my floor is done. It is a great feeling of accomplishment though isnt it? I know that when I am done this will hopefully outlast the rest of the car. I cut my floor out of a donor car to keep the original look. Good job. Your work will definately inspire others.
Kevin
Old Jan 7, 2010 | 11:20 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I know you said you are on a tight budget. I would of course recommend one of those sites above but you could go to Craigslist or even the JY to find a decent used set. I scored a decent full set of Lear Sigler seats from an 82 Camaro. Not perfect but much better than my ripped up smoke smelling original seats. There is a lear Sigler thread on here and pics of my seats are on there.
Kevin
Old Jan 7, 2010 | 11:44 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks a lot for the info. The crappy thing is that my friend had those seats for his maro. Took them out and then decided he didnt want to do the project and he brought the car to the crusher. Waste of those seats and I coulda got them for cheap / free.
Old Jan 7, 2010 | 11:19 PM
Car: 89 IROC
Just what is in my build post. My interior looks showroom new (because it is).
Also I don't have the cutouts for the rear speakers. My panels are perfectly smooth (not sure why).
I still need to get some custom seat tracks made so I can install the racing seats.
Old Jan 7, 2010 | 11:49 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Yeah your interior looks really clean and I noticed that your sail panels are solid (after the guy pointed it out) aha. Sweet
Old Jan 15, 2010 | 08:27 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
free bump for you... i love the work you're doing. It's nice seeing thirdgens getting saved, even V6 models.
Old Jan 17, 2010 | 01:26 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thank you sir. There is a lot more work I have done. I am updating my cardomain page right now.
Old Feb 5, 2010 | 09:08 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
It's definitely come a long way. Good luck with it. If you need any parts for it be sure to check us out. Thanks!!!
Old Feb 6, 2010 | 03:31 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks. I'm planning to come to your thirdgen fest '10 so ill be able to get all the parts I need then.
Old Feb 6, 2010 | 05:20 PM
Former Sponsor
Car: Too many
Great, I hope you're able to make it down. We've got another member here who comes down from Canada every year and there's been a few other people talking about coming down from Canada this year. Hopefully, we'll see you there!!!
Old Feb 6, 2010 | 05:34 PM
Car: 89 IROC
Here's a shot of my NOS interior panels.
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Street Lethal
Aug 12, 2015 11:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
